Help
biscuits or dowels
This is a discussion on biscuits or dowels within the Tools and Woodworking forums, part of the General Woodworking category; looking at buying craftsman plate jointer $99. I tried a cheap manual dowel kit for ...
Old 05-18-2009, 01:18 AM   #1 (permalink)
Barry99's Avatar
First Name: Barry
Barry99 is on a distinguished road
Default biscuits or dowels
Report Post Report This Post!
looking at buying craftsman plate jointer $99. I tried a cheap manual dowel kit for $13 from HF but dowels end up off 1/8" or so. Understand plater jointer is very accurate. Would like to hear pros and cons. Links to product would be most appreciate.
Thanks Barry
Barry
~Is it measure twice and cut once, or cut twice and measure once?~
Barry99 is offline
Old 05-18-2009, 02:14 AM   #2 (permalink)
RobW's Avatar
First Name: Rob
RobW is on a distinguished road
Hi Barry
Biscuits have a place and I use them but when ever I can I use dowels, I think they so much better. Take a look at dowelmax.com this is an amazing tool and it works 100% of the time,I love it.
Rob
When the student is ready, the teacher will appear
Failure is the lubricant of success
RobW is offline
Old 05-18-2009, 05:43 AM   #3 (permalink)
xplorx4's Avatar
First Name: Jerry
xplorx4 is on a distinguished road
You don't need a plate joiner, just use your router with a slot cutting bit. In a recent article in Wood, or Woodworkers Journal the router was use to cut a continuous slot to join two halves of a table or wookbench. I have an older plate joiner (but like new) PC that my Dad left me and have use it with success. I have also used one of the not so perfect dowelling jigs that I got at HD and it has done well also. I am going to try the slotting bit with the router when I join the two tops at my island assembly. I plan to align it with the biscuits and then secure it from the bottomed son as not too glue it for when I take it apart sometime in the future. I would say if you plan to go the plate joiner get a good one and not cheap. Dads was not the best and tends to want to move as the blade engages the wood, I adjust for it by holding it to the edge little more. I am sure others have used the router in the same way.
Lamentations 3:22-23
xplorx4 is offline
Old 05-18-2009, 07:31 AM   #4 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Jerry, the biscuit jointer and slot cutter BOTH have their uses, but to answer Barry's question, a biscuit jointer is a very valuable tool, with todays' high tech. adhesives, a glue joint is stronger than the wood itself and so all that is normally required is a means of aligning the pieces to be jointed and this is where the biscuits come into their own. Bear in mind that no measurements are needed, just align the two pieces and draw a freehand pencil line at the centre points, plunge the cutter, move it a little side to side to allow heaps of sideways adjustment and it's done. I promise you Barry that it will be the best $99.00 that you ever spend on tools.
The third shot is jointing boards for a small coffee table, biscuits are perfect because there is a big glue surface, shot two of the carcass is a different matter, there is only a small glue area so we needed the extra strength of dowels.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 05-18-2009, 09:09 AM   #5 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Harry
The project below would be great job for the pocket hole screws,you know how I feel about dowel pins.. ( if want a ltem to turn put it on a round pin )
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 05-18-2009, 09:27 AM   #6 (permalink)
Noob's Avatar
First Name: Paulo
Noob is on a distinguished road
Have any of you used one of these biscuit making router bits?
Biscuit bit LINK
At $35, it's a tempting deal but I've never used biscuits before. I've read biscuits are more for alignment while gluing and dowels are more for strength, but that will probably open a can of worms.
Noob is offline
Old 05-18-2009, 09:42 AM   #7 (permalink)
bobj3's Avatar
Hi Noop
Yes and slot cutters also..
http://www.mlcswoodworking.com/shops.../biscuits.html
Biscuit bit LINK
Part Finder
Bob J.
Old 05-18-2009, 11:59 AM   #8 (permalink)
rwyoung's Avatar
First Name: Rob
rwyoung is just really nicerwyoung is just really nice
The PC biscuit cutter is a very accurate and solid piece of machinery. Plus it comes with a second cutter for the #FF biscuits. The Sears units are either/or. I believe they have one that does standard sizes (20, 10, 0) and one that only does the FF.
That said, the PC is much more than $99. And biscuits are not really intended for strength although they can create a joint stronger than a butt joint (it is a minature floating tenon after all). But nowhere near as strong as a true M&T, or multi-dowel joint. Depending on whose test you believe they are just above or just below pocket hole screws in strength if properly done and glued.
Good for panel alignment, face frames, face frame attachment (alignment again) and quick carcass construction. I've done all these with mine as well as used it while making some jigs that required good alignment between perpendicular pieces.
Rockler has a nice $10 two hole doweling jig that is quite accurate for 3/4" stock and if you remove the clear plastic fence and replace it with hardboard+sandpaper you can make very accurate joints. I think there is a good thread at sawmillcreek.org about this jig. Unfortunately I don't have a link to post at the moment.
rwyoung is offline
Old 05-19-2009, 01:32 AM   #9 (permalink)
harrysin's Avatar
Hi Harry
Bob, if I were still into regular furniture making I would definitely get a top of the range pocket hole jig. Having said that, my foot operated router lifter makes dowelling a very fast operation and so simple compared to all the fancy jigs that over the years I've spent a small fortune on.
Harry
harrysin is offline
Old 05-21-2009, 12:37 AM   #10 (permalink)
Barry99's Avatar
First Name: Barry
Thanks all for the good info.
Harry, I do have one question. Your above statement about foot operated router lifter makes dowelling fast and simple. Can you explain this a bit more because I am not sure what you mean. Thanks.
Barry
Barry99 is offline
Biscuits vs tenons kolias Tools and Woodworking 14 03-27-2009 09:02 AM
"What is it?" #116 reible What is it? 14 04-04-2005 10:14 PM
Biscuits saltysteele Tools and Woodworking 8 02-14-2005 08:28 PM
dowels boxer Tools and Woodworking 9 11-23-2004 11:05 AM
