| This is a discussion on Working with UHMW plastic within the Tools and Woodworking forums, part of the General Woodworking category; I'm seeking a little advice. One of my table saw upgrades is building a crosscut ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I'm seeking a little advice. One of my table saw upgrades is building a crosscut fence, I chose to build the Super-sled, referenced here:Eagle lake woodworking. The sled has two plastic runners that fit in the mitre slots of the saw. Yesterday, I stopped at my local Rockler and purchased a 3/4" x 4" x 24" piece of UHMW plastic. Unfortunately, this stock is thicker than .750. Will a conventional planer work to take it down to the proper dimension? Are there any special caveats about drilling or cutting this material?
__________________ Sawdust is not dirt | ||
| | #2 (permalink) | |||
| Forum Contributor ![]() |
Hi Lance Just use your table saw/band saw,,the planer will make it a mess...the norm. Just cut a stick or two and then and little trim again on the table saw. No big deal about drilling it.. =========== Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #3 (permalink) | ||
As was said already, UHMW makes a big mess when cutting it. You can use pretty much any cutting tool on it that you can use on wood. | ||
| | #4 (permalink) | ||
Thanks, guys! Full steam ahead on the sled.
| | #5 (permalink) | ||
You were both right about the UHMW being a mess. The saw was full of small hairs and such. Gave me a chance to blow everything clean, anyway. I did throw a stick through the planer to achieve dimension. I didn't have the dust collector hooked up and was surprised to see what looked like 10,000 short straws on the floor. That gave me an excuse to clean the floor.
| | #6 (permalink) | ||
I bandsaw with a fine blade, then handplane to size. Drilling no probem, but don't try to clear the swarfe on the drill while it is running. | ||
| | #7 (permalink) | ||
A little different question but along the same line. Has anyone machined polyethelene? I need a zero clearance insert for my table saw and have been eyeing the wifes plastic cutting board, plenty large enough and smooth. Naturally I will be disavowing all knowledge of it's whereabouts. ![]()
__________________ John Schaben ![]() "I haven't failed, I have simply discovered several hundred ways that don't work" | ||
| | #8 (permalink) | |||
should cut just fine, just dont go too high on the rpm on the mill it will cause the plastic to melt unless you have a real fast feed rate. | |||
| | #9 (permalink) | |||
The wife always knows. She knows. Period. ![]() Anyway, I used some leftover floor boards to make the zero inserts. It is from redoing our floor and it is one of those laminated floor boards. Really strong, smooth, square and temperature/humidity resistant stuff. It is about 1/4 inch thick, fits perfectly into the slot. Quote:
| UHMW table top | newbie1 | Starting Off | 6 | 08-02-2009 07:11 AM |
| UHMW Plastic | RayHeinrich | Jigs and Fixtures | 7 | 04-01-2009 10:29 PM |
| Machining UHMW plastic | pmspirito | Tools and Woodworking | 2 | 09-05-2005 08:41 AM |
| What Router to buy (cutting plastic) | stevegriswold | General Routing | 1 | 07-03-2005 12:56 PM |
| Building a New Router Table-What's the Ideal Working Height? | gerrym526 | Table-mounted Routing | 6 | 02-19-2005 11:13 AM |
