Help
drill press chuck
This is a discussion on drill press chuck within the Tools and Woodworking forums, part of the General Woodworking category; i think i need to replace the chuck in my dp. is there a certain ...
Old 06-06-2009, 09:02 AM   #1 (permalink)
levon's Avatar
First Name: levon
levon is on a distinguished road
Default drill press chuck
Report Post Report This Post!
i think i need to replace the chuck in my dp. is there a certain brand that would be good?? should i think of the jacobs keyless for a drill press. they do sell them for drill presses. ive never done this so i have no experience knowing which to buy?
levon
levon is offline
Old 06-06-2009, 09:10 AM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
HI Levon
Why do you think you need to replace it ?
But yes they do make the keyless for the drill press but they are not cheap,you can get the high end China type or the Jacobs ...
Here's just one link for some
http://littlemachineshop.com/product...1660&category=
http://littlemachineshop.com/product...dID=1204050322
http://littlemachineshop.com/product...dID=1204050117
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-06-2009, 09:14 AM   #3 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
The Chinese keyless chucks do not run true, good enough for wood but not for metal. Jacobs are as good as they get Levon.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 06-06-2009, 09:18 AM   #4 (permalink)
levon's Avatar
First Name: levon
HI Levon
well, the reason i think i need to replace it is when using the 3 inch holesaw this morning, i tightened the arbor and several times on different holesaws, i would hear a ping, and then the arbor would be loose. once while tighteneing it seemed tight then and putting pressure aka hammer on the key it tightened another 5 or 6 rounds..
what do you think?
levon
levon is offline
Old 06-06-2009, 09:29 AM   #5 (permalink)
bobj3's Avatar
HI levon
Most drill presses don't come with the chuck installed and must be put in by the user,,it sounds like it's not set in right.., 2 x 4 and brass hammer,clean the harbor out and with a good hit set it in place....
But if it's the ring gear in the chuck have them replace it free of charge..,the ring is very light in most and they can snap and you will get the " ping " sound if they are cracked..
what do you think?
Part Finder
Bob J.
Old 06-06-2009, 09:51 AM   #6 (permalink)
levon's Avatar
First Name: levon
my reply seems to have disappeared.
the chuck has worked good for several years and is just now showing problems of not locking down tight. ??
levon
levon is offline
Old 06-06-2009, 10:08 AM   #7 (permalink)
bobj3's Avatar
Hi levon
Pop the chuck open,,and take a peek in side...
It's like a walnut shell,,,just tap it and the out side barrel with snap off.
clear as mud I know ...it's a little bit tricky but easy or just get a new one,,The last one I got ,it came from FL..5/8" keyless Jacobs ...if I recall 65.oo bucks...
Part Finder
Bob J.
Old 06-06-2009, 10:13 AM   #8 (permalink)
levon's Avatar
First Name: levon
what is Fl and if i get a jacobs keyless, should i get a new arbor or will it fit on the old one?
levon
levon is offline
Old 06-06-2009, 11:27 AM   #9 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
I wouldn't put a keyless on a DP. It's hard enough trying to get a hand drill tight with those. Stay with a key chuck.
AxlMyk is offline
Old 06-06-2009, 11:29 AM   #10 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
Levon,
I did a Google search for "drill press chuck replacement" and came up with a lot of interesting hits. Here is just one you might want to take a look at...
JACOBS DRILL CHUCKS
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Having some difficulty mounting my router everyman Table-mounted Routing 11 12-18-2009 09:05 AM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 5 04-27-2009 05:11 PM
any fix for a drill press? rprice54 Tools and Woodworking 2 11-21-2006 08:33 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
