| This is a discussion on T track sourcing within the Tools and Woodworking forums, part of the General Woodworking category; I have been on the lookout for an inexpensive source for T track. Rockler, Woodcraft, ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have been on the lookout for an inexpensive source for T track. Rockler, Woodcraft, P tree, et. al. charge inexplicable prices for the stuff. I did get some aluminum extrusion for a table saw cross-cut sled. Pictures are attached, below. That track measures 1"x 1/2" and accomodates a 1/4" carraige bolt. I'd like to find a souce that will accomodate the standard 5/16" T track bolts as I have a few knobs and bolts of that size. Anybody have any suggestions as to a source for the larger slotted T track?
__________________ Sawdust is not dirt | ||
| | #2 (permalink) | ||
| Registered User ![]() Join Date: May 2007 Location: I was born and raised in Holland Michigan First Name: Howard Posts: 1,529 ![]() |
Hi Lance! Have you tried E_Bay, That may be a way to go. Good luck!
__________________ John 3:16 Please fill out your profile, It helps us to know you better | ||
| | #3 (permalink) | ||
Look at McMaster- Carr.
__________________ Don Jeansonne Cajun Woodworker | ||
| | #4 (permalink) | ||
| | #5 (permalink) | ||
Their T Track measures identical to Rockler but it says the track accomodates a 1/4" hex bolt. I wonder if it will accomodate a 5/16" T slot bolt?
| | #6 (permalink) | ||
| Retired Moderator ![]() |
No Lance, it will not. The 1/4" hex bolt T track is the smaller stuff Sears uses. Most other brands use the slightly larger size.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #7 (permalink) | ||
Thanks, Mike, that's what I thought. I'm still on the hunt...
| | #8 (permalink) | ||
| Registered User ![]() Join Date: Aug 2007 Location: Central PA First Name: Thrifty Posts: 152 ![]() |
Lance, I think you're looking at the "T-slot" extrusions. That stuff is readily available in a multitude of sizes from many industrial/laboratory supply houses. Shorter sections are available on eBay. TTG | ||
| | #9 (permalink) | ||
| Forum Contributor ![]() |
Hi Lance eBay Store: Search results for 80 20 8020 Aluminum T-Slot T Slot extrusion 8020 garage sale. I use it all the time. top of the line tee-slot =====
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #10 (permalink) | ||
Is the Miter T-Track & T-Bar from MLCS any good for you. They do a couple of versions. Router accessories Incra do some as well as Woodcraft. Buy T-Track, Jig & Fixture Hardware - Woodcraft.com | ||
| Miter track | Bdog | Table-mounted Routing | 7 | 03-07-2009 10:49 AM |
| T track modification | locoboy | General Routing | 5 | 10-15-2008 03:38 PM |
| Source for 1/4” T Track? | Nickbee | Table-mounted Routing | 5 | 12-01-2007 02:45 PM |
| T Track Toggle Clamps | Pop_pop1 | Table-mounted Routing | 4 | 07-29-2005 02:22 AM |
| A&I Supply & Advantage Track? | Chris47283 | Tools and Woodworking | 2 | 07-10-2005 04:55 AM |
