| This is a discussion on Box joints versus dovetail joints within the Tools and Woodworking forums, part of the General Woodworking category; This study looked at the two and concluded the box joint is stronger than the ... |
| | #1 (permalink) | ||
| Registered User ![]() |
This study looked at the two and concluded the box joint is stronger than the dovetail joint. the author attributes the advantage of the box joint to modern wood glues. Here is a link: Dovetail joint vs box joint rstermer | ||
| | #2 (permalink) | ||
| Retired Moderator ![]() |
You just gotta love a test that is apples against oranges with the resulting fruit punch. The test is in no way accurate. First off those are 1/2 blind dovetails, not through dovetails. To get any kind of meaningful test result the joints should be close to the same size and number, and both should be through joints or halfway joints. Telling me that a joint half the thickness of the material failed before a joint the full thickness of the material does not surprise me at all. Is this Canuck logic?
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #3 (permalink) | |||
rstermer | |||
| | #4 (permalink) | ||
Don't get me wrong. I think dovetails are nice, they are a decorative joint that I will seldom use. I prefer the box joints, but there are so many choices like drawer lock joints, mitre joints, locking mitre joints, mitred rabbit joints... There is no question that the new glues are stronger than the wood. That is well documented. I guess if the joint fits... glue it!
| | #5 (permalink) | ||
There was this disclaimer in the article: "Of course, if I had made a box joint which exactly the same contact area as the dovetail joint, the dovetail joint would most likely have been stronger." So, I think he just wanted to post an article for his own satisfaction. ![]()
__________________ Do as you always do,,, Get what you always get | ||
| | #6 (permalink) | ||
Goes to show you can make an argument for anything using convoluted logic. The dovetail joint is a mechanical joint, the box joint, not. Here's the test; assemble two drawers, one with box joints and one with dovetails (makes no difference through or half blind). Assemble them dry, no glue. Now close the drawers repeatedly and see which drawer falls apart. Box joint fails every time. The dovetail is superior by design, not by luck or by the use of todays "modern glues". Dovetail joints are the benchmark, always will be no matter how many fancy or ingenious router bit joints manufacturers dream up. Open a drawer on a finely crafted piece or reproduction and you'll see dovetail joinery. Not box joints. Study the elite craftsmen of any era and the joint used on casework and drawer construction is invariably the dovetail along with the mortise and tenon. Not the box joint. Lastly, all you need to know about the knowledge and skill level of that author is in his last paragraph: "Fact is, for drawers, I have mostly just used nailed rabbet joints". Last edited by jmg1017; 06-17-2009 at 07:32 AM. | ||
| | #7 (permalink) | ||
| Forum Contributor ![]() |
Hi Guys This just my 2 cents Through dovetails hands down are the best,,,they are so quick to put in place ![]() You can made a drawer/box in about 5 mins. or so..they are strong and are self locking so to speak..unlike many of the other wood joints.. ===========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #8 (permalink) | ||
Here is a link with 3 articles regarding joint failure. I didn't attach the PDFs here because of there size, but you can get them here: Joint failure LINK | ||
| | #9 (permalink) | ||
| Registered User |
It appears the contact (surface) area of the glued finger joint is at least twice larger than the half blind dovetail joint in test. As mentioned above the comparison is between apples and oranges. Would be interested in the comparison between 3 finger joint vs 5-6 through dovetails .Regards | ||
| | #10 (permalink) | ||
"Is this Canuck logic?" Not my experience Mike, who has ever broken a draw with either box or dovetail joints. Sure the latter is prettier and as Bj said, faster to make but we're talking about strength.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| Dovetail Spline Joints with the OP jig | bobj3 | Jigs and Fixtures | 14 | 03-30-2009 10:18 PM |
| Drawer joints - Box vs. Dovetail vs. ??? | ChevyNomad | General Routing | 2 | 01-14-2005 10:20 AM |
| dovetail spline joints | reible | Jigs and Fixtures | 7 | 10-02-2004 01:50 PM |
