Help
Makita 4014NV Blower remove broken fan
This is a discussion on Makita 4014NV Blower remove broken fan within the Tools and Woodworking forums, part of the General Woodworking category; Hi I am looking to replace broken fan (Item number 9 in the link below) ...
Old 06-20-2009, 10:02 PM   #1 (permalink)
First Name: Zillah
zillah is on a distinguished road
Default Makita 4014NV Blower remove broken fan
Report Post Report This Post!
Hi
I am looking to replace broken fan (Item number 9 in the link below) for makita 4014NV blower
Code:
hxxp://xxx.ereplacementparts.com/makita-4014nv-blower-parts-c-97_16559_230.html
But I could not remove it , any advise how can I do that ?
please replace hxxp with http
and replace xxx with www
I could not post the direct link because I have got less than 10 posts
zillah is offline
Old 06-22-2009, 05:15 PM   #2 (permalink)
dutchman 46's Avatar
First Name: Howard
dutchman 46 is on a distinguished road
Will this work? Makita 4014NV Parts List and Diagram : eReplacementparts.com I got to it by highlighting repla===and includinghtml. I could navigat to it. Looks that you may have to order one. Doesn't look as it would be to hard.
Welcome to Router Forums. Please tell us where you are from. Enjoy the forum
John 3:16
dutchman 46 is offline
Old 06-22-2009, 05:25 PM   #3 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Zillah
Looks like the type that needs a puller (J hook type) to get it off,look on the fan for some threaded holes/holes.....to put the puller in place.........or look for the tinnerman push on cap type under the fan..or a Allen set screw holding it in place........
stem the type you can sometimes see on small wagon wheels ...
see item part number 9
eReplacementparts.com : Fan 110 [241888-1] - $8.39
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-22-2009, 07:30 PM   #4 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
Item 10 is a pan head screw that appears to hold it in place.
AxlMyk is offline
Old 06-22-2009, 08:23 PM   #5 (permalink)
bobj3's Avatar
HI Mike
Your right item number 10
Part Finder
Bob J.
Old 06-22-2009, 10:48 PM   #6 (permalink)
First Name: Zillah
I did remove that but still I could not remove the fan.
I can not find the prope place to fit a puller ,,,,,,,might be there are different type of puller please suggetc one (online picture)
Please see the actual fan for my Makita
hxxp://img13.imageshack.us/i/panoramaszo.jpg/
zillah is offline
Old 06-23-2009, 08:12 AM   #7 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
It sounds like there's a burr on the shaft. You'll probably have to clamp the armature, with suitable packing, in the vice and rotate the fan to and fro whilst applying upward pressure.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 06-23-2009, 08:17 AM   #8 (permalink)
First Name: Zillah
The problem I can not hold of the armature
zillah is offline
Old 06-23-2009, 08:25 AM   #9 (permalink)
harrysin's Avatar
What I had in mind was a block of hardwood, drill a hole with a forstner bit close to the diameter of the armature, cut the block in two, place one half each side of the armature and clamp into the vice. If you don't have a suitable forstner bit use a jig, scroll or band saw and if you don't have any of these, don't worry, drill a series of holes close together then knock out the centre with a sharp chisel. There is always a way Zillah.
Harry
harrysin is offline
Old 06-23-2009, 08:51 AM   #10 (permalink)
bobj3's Avatar
Hi zillah
see below
pullers that will do the job ▼
http://www.harborfreight.com/cpi/cta...temnumber=5469
others ▼
http://www.harborfreight.com/cpi/cta...emnumber=30305
http://www.harborfreight.com/cpi/cta...temnumber=4876
Part Finder
Bob J.
