| | #1 |
| Registered User Forum Fanatic | I am told that the UHMW, (the white slicky plastic), machines well. but how quickly does it dull planer and jointer knives? Is it sandable? I have no experience with this stuff and would llike to here from those that do. |
| | #2 |
| Registered User | Have noticed no adverse effects on my planer or joiner knives, but cupping does occur in the planer process if you try to strip off to much material at one time. Sands well. I use poly glue & SCREWS because this stuff does not bond well at all. I purchased a special two part glue from a marine dealer, "liquid marinetex" but have not tried to use it yet. Anxious to read other responses to your question. |
| | #3 |
| Registered User Forum Geek | UHMW machines similar to wood and is easy on the tools. In addtion to what has been said, thin pieces(less than 1') need to be supported or they will curve(warp ?) a great deal. HD polyethylene is cheaper and works about as good. I have used super glue as well as epoxy to adhere polyethylene. Good luck. regards jerry |
| I can't get Avery labels to stick to plastic container | S Bolton | General Routing | 25 | 10-19-2007 09:03 AM |
| glue for plastic laminate | S Bolton | Table-mounted Routing | 8 | 09-29-2007 12:05 PM |
| What Router to buy (cutting plastic) | stevegriswold | General Routing | 1 | 07-03-2005 12:56 PM |
| Plastic | Drick | General Routing | 2 | 03-06-2005 09:53 AM |
| UHMW slick strips attachment | pmspirito | Jigs and Fixtures | 4 | 11-07-2004 05:50 PM |
