External Speed Control on Bench Grinder - Router Forums
post #1 of 13 (permalink) Old 08-16-2009, 09:03 AM Thread Starter
TRN_Diesel's Avatar
I have wanted to buy a bech top grinder and most do not come with a speed control on them so I was thinking why not add an external speed control?
You can buy some for a router is it possible to adapt this to a bench mount grinder?
Has anyone tried this before and had any success?
TRN_Diesel is offline
post #2 of 13 (permalink) Old 08-16-2009, 12:08 PM
xplorx4's Avatar
First Name: Jerry
Good idea, I will give it a try later today.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 13 (permalink) Old 08-16-2009, 12:36 PM
Mike Wingate's Avatar
First Name: mike
All grinding wheels have a maximum speed, generally based upon the diameter of the wheel.Slower speed equals cooler grinding. But it takes an instant longer. A slower speed is handy if you change grinding wheels for other rotary devices. All the fixed base grinders that I have used have been single speed.
Mike Wingate is offline
post #4 of 13 (permalink) Old 08-16-2009, 01:37 PM
Hi Dan
I have and the router control device works but it comes down to what type the motor is...and amps.
Router control device 15 and 20 amp. types.. can be had.
The one I tried was a 15 amp.type..
post #5 of 13 (permalink) Old 08-16-2009, 02:37 PM Thread Starter
TRN_Diesel's Avatar
Thans Jig I assume then if the device (speed adjuster) is rated for 15 or amps you can use it as long as the motor on the grinder does not draw anymore than the rated device.
I will have to experiment and maybe even try a dimmer switch for a light and see if that works.
post #6 of 13 (permalink) Old 08-16-2009, 04:56 PM
Hi Dan
20 amp speed control below
MLCS router speed control and Foot Switches
The dimmer switch will not work,you will cook in about 2 mins. or so or less .. ,I know you will say they say that it's rated at 15 amps. but it can't take on....it's a very light duty pot..or slider..
post #7 of 13 (permalink) Old 08-16-2009, 06:31 PM
Cassandra's Avatar
First Name: Cassandra
Hi Dan:
Forget the lamp dimmer switch! As BobJ has said, they won't last. Reason is that the lamp dimmer switches are made for low inductive loads, preferably a resistive load (incandescent lamps.) Motors are high inductive loads, by nature. Current flow in a high inductive load lags the voltage by a significant amount. The lag is something we in electrical engineering call phase angle.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #8 of 13 (permalink) Old 08-16-2009, 10:53 PM Thread Starter
TRN_Diesel's Avatar
Ok thanks I learned something today.
post #9 of 13 (permalink) Old 08-16-2009, 11:21 PM Thread Starter
TRN_Diesel's Avatar
Well after reading and learning thanks to the peopl eon this forum I have come to the realization that it may just be easier to buy a grinder with a variable speed built right into the unit.
The grinders I have looked at are about $60.00 and then you add the variable speed unit and it is over $100 plus shipping.
So Sears has one for $100 with built in speed control :
CRAFTSMAN®/MD 6" 2.8-amp Variable-speed Bench Grinder : Sears Canada
Thanks for all your help it is very much appreciated.
post #10 of 13 (permalink) Old 08-16-2009, 11:37 PM
crquack's Avatar
Router motors and most bench grinder motors are significantly different. The commercially available speed control for routers will not AFAIK work on a bench grinder.
crquack is offline
Human Verification
Blown Hitachi M12V speed control bypassed honyacker General Routing 13 04-22-2017 10:25 AM
Freud FT200E speed control module stjimm General Routing 8 06-28-2015 06:28 PM
Router Speed Control Barreller General Routing 15 06-06-2009 03:17 PM
Dewalt DW670 + speed control Thrifty Tool Guy Portable Routing 11 09-16-2007 06:42 AM
External speed control for Maktec edilson Tools and Woodworking 1 10-25-2006 09:06 PM
