Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 10-11-2005, 08:57 PM   #1
reible
Supreme Forum King
reible's Avatar
Default help with sawbuck
Hi,
I have a project I want to do and that is to make a "sawbuck". You may not call "it" that but when I grew up that is what they called them in northern WI. In those days almost everyone had one as supplmental wood heat and being poor you did your own wood. I recall seeing lots of designs depending on who made it and how good they were at woodworking. Some used logs others 2X4's or 2X6's...... Some lashed them together some pegged them, nails, wire, spit....... OK maybe not that last one.
I'd like to make one out of either 2X4 or 2X6 and make it look like a craftsman made it. I will not be doing any major "logs" but might do a few tree limbs but a lot of its use is for looks. I have some used 2X6 cedar so that will most likly be my wood choise.
The design I'm picturing is a X=X==X looking thing, if you can picture that. I could just guess at things but if someone has made one or has plans for one or has any idea of what I'm talking about and wants to comment please do so.
Thanks,
Ed
Old 10-11-2005, 10:38 PM   #2
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Hi Ed used to have one when I was a kid on the farm. All I did was put runners on the ground with to running cross members holding the X's together. It was pretty crude but it worked. Now that I have some knowledge of tools. I would notch out for every connection. I don't know where off hand you would get plans for one it's basicly hit or miss type project.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 10-11-2005, 11:46 PM   #3
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Hi Ed,
http://www.motherearthnews.com/libra...e_Crosscut_Saw
http://www.motherearthnews.com/libra...f_Two_Sawbucks
http://www.motherearthnews.com/libra...r_s_Log_Lifter
Check out the links above. These may be what you are looking for.....Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 10-12-2005, 12:32 AM   #4
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Here's a site I found for you Ed hope it helps it's on a pdf file though. Here is the site address. http://woodworkers.lightwire.net/projects.htm Hope this helps. Ed if you can't get a copy email me and I'll print them and send them to you.
Glenmore
Old 10-12-2005, 01:01 AM   #5
reible
Supreme Forum King
reible's Avatar
Originally Posted by Pop_pop1
Hey I had forgot about these people.....
Could you check your links, I get a lavender shaded box with some message that says the cover png doesn't exist????????? Odd to say the least.
Ed
Old 10-12-2005, 01:09 AM   #6
reible
Supreme Forum King
reible's Avatar
Thanks...... I have no problems with pdf been using it since it was invented.
Interesting design and a good starting point....... hey when we had these only some loggers had chainsaws....... had to put your foot somewhere for the draw stroke and I guess you would put a lot less strain on them using a chainsaw, mostly just the weight of the log.
Ed
Old 10-12-2005, 09:00 AM   #7
kp91
Forum King
kp91's Avatar
First Name: Doug
Ed
If the PDF's won't open, try saving them to your desktop then opening them. Sometimes that helps....
1 John 1:9
Old 10-12-2005, 11:06 AM   #8
reible
Supreme Forum King
reible's Avatar
Site must have been down late last night as when I tried this morning everything was working and the pages came up.
Thanks,
Ed
Old 10-13-2005, 03:23 AM   #9
Pop_pop1
Forum Fanatic
Hi Ed,
I've had a lot of computer and email problems yesterday and last night so I just got your message about the links. If you go to www.motherearthnews.com and do a search for crossbuck, and it will find those 3 articals. Good luck.......Chuck
PopPop
Old 10-13-2005, 11:34 PM   #10
Warren
Jr. Member
Warren is on a distinguished road
I built the one on Glenmore's link a couple of days ago. Took all of 30 minutes. All 2x4 construction is over doing it. I think 1x3 or 4 will be more than sufficient for the cross pieces. Cut the chain a couple of inches longer then you feel you'll need so you can open up the supports for extra big log. I work in a fairly damp area and it's nice to beable to hang the thing up on the side of shed instead of leaving the legs mired in the dirt.
Warren is offline   Top - Reply with Quote
