Rate This Thread - cutting plywood on a 45 with a router.
Thread Tools Display Modes
Old 10-19-2005, 12:41 PM   #1
joe carter
New Member
joe carter is on a distinguished road
Default cutting plywood on a 45 with a router
what is method for cutting a piece of plywood on the top edge for putting top and side together
thanks
joe
joe carter is offline   Top - Reply with Quote
Old 10-19-2005, 01:41 PM   #2
kp91
Forum King
kp91's Avatar
Joe,
You can use a 45 degree bit to cut a miter on a piece of plywood, but it doesn't always work that great. The veneer can occassionally fuzz or split, making a joint that doesn't look that great.
You can use a rabbet joint, which will hide all but a little end grain, which makes a fairly strong joint, or you can edge band the ply with hardwood, and miter the joint that way.
1 John 1:9
Old 10-24-2005, 06:00 AM   #3
Birchwood
Sr. Member
Birchwood is on a distinguished road
Default Cutting plywood on 45 degree
I built a simple jig, lake the boys on Router Workshop use, and it cuts plywood at a 45 just fine. Pretty simple to make; just a piece of anything cut at 45 on your table saw, or with a hand-held circle saw, then clamped to your table or screwed to a piece of 1/4 MDF or something similar. Clamp it to your table and use a trim bit (I used a 1 1/2"). Hard for me to explain, but trust me-if I can do it ANYBODY can do it.
Birchwood is offline   Top - Reply with Quote
Where can I find this Slick method for cutting router plate opening into table Peter Sanders Table-mounted Routing 23 01-23-2008 08:42 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
