Rate This Thread - Planer.
Thread Tools Display Modes
Old 10-30-2005, 04:41 PM   #1
viper1
Dedicated Member
viper1's Avatar
viper1 is on a distinguished road
Default Planer
Anyone have a fix for a delta 12 " planer that rollers slip on?
God created man, then woman and man said, Give me my wood shop!
viper1 is offline   Top - Reply with Quote
Old 10-30-2005, 10:49 PM   #2
Routerbit
Member
Routerbit is on a distinguished road
Have you cleaned the rollers, sharpened the blades and keep the cut to a small increment??
Routerbit is offline   Top - Reply with Quote
Old 10-31-2005, 06:00 PM   #3
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Viper I had this problem with my Dewalt planer. I put wax on my tables. If that don't work take the advise from Routerbit. Because what he says could be the problem. But try some wax on your tables just don't over do it because if you use to much you could get a film on your wood.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 10-31-2005, 08:05 PM   #4
GoonMan
Forum Geek
GoonMan's Avatar
GoonMan has a little shameless behaviour in the past
I just went through feed problems with my Planer last week and could not figure out what was wrong. It ended up being dull blades that was causing the problem and talk about noisy it would wake up the whole neighbor hood when I would try to plane any kind of wood but Oak was the worst. LOL I also thought it was slipping rollers so I cleaned them and I also waxed the table again but still no good. So the next choice was change the blades. About 30 minutes later I was up making saw dust again. WOW it was just like the day it was new. I changed my first set after running about 50 Pallets worth of wood throught it they are rough on blades.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ Twin Oaks Mill
GoonMan is offline   Top - Reply with Quote
Old 12-10-2005, 08:30 AM   #5
Chuck Ross
Jr. Member
Chuck Ross's Avatar
Chuck Ross is on a distinguished road
Look to see if you are in a bind. When you bring down the head lock and force it to the table that will put to much pressure on the wood. Look at your infeed roller stand. And look how much you are removing at one time. Look at the wood is it bowed if so witch way.
Chuck Ross is offline   Top - Reply with Quote
Old 01-08-2006, 11:30 PM   #6
gjbivin
New Member
gjbivin's Avatar
gjbivin is on a distinguished road
I have a Ryobi planer that was developing the same problem. I UNPLUGGED IT, cranked the head all the way up and cleaned the rollers with acetone. It seems to have fixed the problem. You have to "bump" the power a few times to rotate the rollers to new areas to be cleaned -- wait for everything to stop and pull the plug again before putting your hands back down there! I tried turning the head by hand to turn the rollers, but the gearing is so high that it would take all day to get them to rotate once around. Oh, and be really careful not to cut yourself on the blades -- DAMHIKT. You should carefully turn the cutter head so that the blades are hidden before you work on the rollers each time. I also waxed the bottom and infeed and outfeed tables.
gjbivin is offline   Top - Reply with Quote
Old 01-09-2006, 09:04 AM   #7
jerrymayfield
Forum Geek
It would be easier on the artificial rubber to use naptha, acetone is very strong.
Regards
Jerry
Old 01-12-2006, 01:31 PM   #8
gjbivin
New Member
gjbivin's Avatar
Regards
Jerry
Thanks. I'll remember that the next time I have to clean the rollers.
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
Planer Jigs.... challagan Tools and Woodworking 7 09-29-2007 11:09 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
used planer reikimaster Tools and Woodworking 16 09-09-2007 09:03 PM
I need help! Dewalt Planer Question FordPrefect Tools and Woodworking 4 12-12-2004 12:19 PM
