Thread Tools Display Modes
Old 11-20-2005, 11:27 AM   #1
g-man
Dedicated Member
g-man's Avatar
g-man is on a distinguished road
Default Bradpoint drill bits
Anyone know how to sharpen bradpoint drill bits? If so how is it done?
Gary
g-man is offline   Top - Reply with Quote
Old 11-27-2005, 01:16 AM   #2
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
Mark is an unknown quantity at this point
g-man, im not sure of a specific method, but you could always sharpen your own drills on a grinder with a jig or simply offhand.
Mark,
Administrator and Technician of RouterForums.com
Contact RouterForums.com
Refer a friend to RouterForums.com!
Mark is offline   Top - Reply with Quote
Old 11-27-2005, 04:11 AM   #3
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Gary.....Brad point twist drill bits are ground on a dedicated tool grinder to follow a pattern. Grinding them free hand on a bench grinder is all but impossible. You can do a grind that I have used for years for drilling sheet metal that is simular though. It can be done free hand on a bench grinder by first dressing the wheel, insuring sharp, square edges on the wheel. Use the edge of the wheel and grind a "V" in each side of the bit's cutting edges at about a 45 degree angle. The resulting profile of the bit will resemble a "W", with the middle point being longer than the outside points, this will be the pilot that guides the bit. It will cut first in the center, then the outside, then the area between the center and the outside perimeter of the bit. These will make a neat, clean hole in thin sheet metal and in wood. It will take some practice to get the relief angle and leading edge just right and even on both sides, but it will work.
If your bits are good high quality bits, I'd take them to a tool sharpening service. If not, you'd be money ahead to just replace them.
Good luck with it........Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
my old drill is showing its age ntreaster Tools and Woodworking 2 06-28-2008 12:57 PM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 03:36 AM
Drill safety AxlMyk Lobby 5 04-13-2007 08:27 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
