Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 12-23-2005, 12:26 AM   #1
BlackSilver
New Member
BlackSilver's Avatar
BlackSilver is on a distinguished road
Question Ryobi Re600 speed control
I have a Ryobi Re600 router, a few years old, pretty much on permanent duty under my router table.
Lately, for no apparent reason the speed goes to full-throttle, and cannot be adjusted. Turn it off and usually it will work just fine when you turn it back on. The problem seems entirely random --- router may work fine for several hours, or maybe just a few minutes, before the problem re-appears.
Thinking sawdust in the variable resistor, I pulled the circuit board open, inspected it for bad solder joints, and blew it off with dry air and electronic contact cleaner, but didn't seem to affect the problem.
Anyone else had this issue? What was the problem?
Hans
BlackSilver is offline   Top - Reply with Quote
Old 02-06-2008, 05:55 PM   #2
Keith Kenner
Keith Kenner is on a distinguished road
I am having a problem simular to yours. The router .... has intermitnent power on off on off. I took the top off and there is a speed sensor that rides the top of the shaft and a small circuit board that has a transistor wired in next to that. I unpluged the small circuit board and it seemed to improve, which leads me to believe that the small circuit board is bad. I found this blog while looking for that board. Do you have the parts break down for this router Ryobi re 600?
Keith Kenner is offline   Top - Reply with Quote
Old 10-03-2008, 01:10 PM   #3
billybob66
Jr. Member
billybob66 is on a distinguished road
I have the same router, which is going to do permanent duty in my new router table. It's a powerful beast, perfect for this purpose. As yet, I've not experienced the problem you speak of. I would imagine the fix is not too cheap either, but I haven't checked.
Another possibility would be to plug the router into an aftermarket speed control. They can usually be had for about 30 bucks, and can be mounted wherever it suits you!
billybob66 is offline   Top - Reply with Quote
Dewalt DW670 + speed control Thrifty Tool Guy Portable Routing 11 09-16-2007 07:42 AM
Blown Hitachi M12V speed control bypassed honyacker General Routing 7 09-14-2007 10:41 PM
Speed Control Switch jfacteau General Routing 1 03-08-2007 04:39 PM
External speed control for Maktec edilson Tools and Woodworking 1 10-25-2006 10:06 PM
Ryobi RE600? Toller Table-mounted Routing 2 09-28-2005 12:50 AM
