Rate This Thread - Spade bit sharpening.
Thread Tools Display Modes
Old 01-01-2006, 08:17 AM   #1
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Default Spade bit sharpening
Was doing some wood boring to run some cable and discovered that one of my spade bits is too dull to be of any use. What is the best way to sharpen these.. or is it better to just toss it and buy a new one? I was thinking of trying to touch the edge up with a file as there are no nicks or gouges in it.
Thanks in advance
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 01-01-2006, 09:23 AM   #2
jerrymayfield
Forum Geek
You can touch up the blade without any problem, but just as with morticing chisels you want to stay on the inside so you don't change the diameter.
Regards
Jerry
Old 01-01-2006, 06:11 PM   #3
Hamlin
Supreme Forum King
Hamlin's Avatar
When my grand dad was still doing cabinetry work, he sharpened most "spade" bits with just a small flat file.
Old 01-01-2006, 09:18 PM   #4
BrianS
Forum Geek
BrianS's Avatar
I suppose it's a bit late, but I should have mentioned the small "spurs" on the outboard side of the bit. In looking at the bit, it appears that the inboard side of the spur is a cutting edge, as well as the bevelled edge at the end of the spade. Not sure if I have a file that small, but then the tool store is just down the road.
Brian
Old 01-02-2006, 11:15 AM   #5
Hamlin
Supreme Forum King
Hamlin's Avatar
If you don't have or can't find a file that small, try an emery board or you might try a very fine grade of sand paper, 400-800 grit. Just remember, sand/file very lightly, just enough to remove the spurs. Spade bits, I've noticed spade bits have a tendancy of getting spurs on them. If all you're going to be doing is running wiring, try getting auger bits. They hold up much better than the spade bits. They also "clean-out" much better. (Removal of the wood chips)
Lathe tool sharpening jig curiousgeorge Woodturning and Lathes 4 01-11-2008 11:10 PM
sharpening chisles Attie Marais Introductions 6 11-27-2007 03:39 PM
spent some time sharpening... reikimaster Tools and Woodworking 7 10-01-2007 09:03 AM
Sharpening (NOT router bits) reikimaster Tools and Woodworking 4 10-19-2006 10:49 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
