Thread Tools Display Modes
Old 01-07-2006, 02:21 PM   #1
reds_21
Forum Fanatic
reds_21's Avatar
reds_21 is on a distinguished road
Default rockler dvd tower
due to my in experience, has anyone ever built the cd/dvd tower offered through rockler??? they offer the plan for free and the question i have is what is the best way to apply screws in the base of the unit so it does not wobble. with it being 6 ft in height it seems that it would wobble. the thickness of the wood is 3/4" thick and is there a certain procedure that i should follow to fasten the screws???
shawn
reds_21 is offline   Top - Reply with Quote
Old 01-08-2006, 06:15 AM   #2
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
I just looked at the plan and the screws are put in from the bottom. Using flat head screws, properly countersunk into the bottom will not cause the tower to wobble.
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 01-08-2006, 08:07 AM   #3
reds_21
Forum Fanatic
reds_21's Avatar
thank you pop!! does the length of screws matter? should they be a few inches or not even that?
Old 01-09-2006, 12:23 AM   #4
Pop_pop1
Forum Fanatic
Refering to figure 2 of the plan the bottom is made up of two pieces (D & E) stacked and the main box (C) attached to them. I would use yellow wood glue between C & D and 2" flat head construction screws countersunk below the surface. To attach E to D use yellow wood glue & 1 1/4" flat head construction screws countersunk flush. The location of the screws is indicated on the drawing. Don't forget to drill pilot holes for the screws.
PopPop
Old 01-09-2006, 09:48 AM   #5
reds_21
Forum Fanatic
reds_21's Avatar
awesome, thank you pop!!
shawn
Using a Rockler Router Table ArtShapiro Table-mounted Routing 9 12-15-2007 02:53 AM
Rockler dovetail jig template Mike The Bargain Bin 1 07-14-2007 09:07 PM
KM12VC is odd-sized for Rockler table? badpacket General Routing 4 02-01-2006 09:52 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
rockler dovetail jig reds_21 Jigs and Fixtures 5 02-05-2005 04:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
