| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Forum Fanatic | can anyone suggest a good place to buy saw horses that WORK!!! i have bought the brackets from HD in the past but after awhile they become loose and start wobbling. now that could happen from the user that made them (ME) but the quality in my opinion sucks!!! is there a place that carries them that you guys use and really like the quality???? |
| | #2 |
| Registered User Forum Geek | I bought some from Lowes that are metal, foldable for storage, and height adjustable. I think that it was Skil brand. I really like them for the above mention reasons. The only downside that I have found, if used on dirt or soft surface, you will need to put something under the legs to make them not sink into the ground.
__________________ It's all good till it's no good anymore. |
| | #3 |
| Registered User Forum Fanatic | thanks rh111, are the pastic saw horsses better or worse than the metal horses? |
| | #4 |
| Registered User Forum Geek | I personally considered the same option as you when looking at them. I went with the metal ones as I think that they will be better in the long run. I have actually used a pair of them as a platform to work on by setting a board across the top. When I was looking at them, I went to the store and set them both up and looked at them, tested them out, etc.. to see what they were like. The metal ones that I am talking about take a little more time to set up and adjust than some of the others, but I felt that they were better for the value than some of the others. I also liked the fact that when they are folded and closed down for storage, they take up not much more space than about a 3 ft 2x4.
| | #5 |
| Registered User Supreme Forum King | The plastic ones are a bit more forgiving if you by chance miss with your saw. The metal ones however, will support more weight. There are a few wood books that have plans to build your own. Pretty simple ways of building them and they are seem to be solid. Personal preference I suppose. I have both. Considering I do a lot of metal work, I can't pick one over the other. |
| | #6 |
| Registered User Forum Fanatic | thanks hamlin |
| | #7 |
| Registered User Supreme Forum King | i have had a set of plastic benches for the past 2 years .they are great for light duty .they are pretty tough for being plastic and very portable. for heavy duty i use wood benches. skill saw blades don,t go to well with the steel benches. steel benches are good but you have to be careful with saws. ![]() Last edited by cranbrook2; 01-11-2006 at 08:48 PM. |
| | #8 |
| Registered User Supreme Forum King | Your welcome. If you'd like, I can try to find some plans I've found. I'll try to post links to them. But, won't be able to do that til this weekend. |
| | #9 |
| Registered User Sr. Member | I've made two sets and bought one. I used the galvanized steel brackets and was very disappointed. Then I made a fully wooden set that don't wobble and have served me well for several years. I keep them in the garage. My shop is in the basement and I only have 170 feet, so a fold-up set was needed. The plastic set (Stanley) seemed a good choice. They fold up and can hang on the wall or go behind a bench, and they don't weight anything. They've held up very well and are very stable. Berry in St. Paul |
| | #10 |
| Registered User Forum Fanatic | thanks everyone,,,,,,,,,,,,,,,,, i hear what your saying between the three. i think i'd rather stay away from the metal ones just for the fact that if you accidentally go through the metal you just jacked your saw blade up. atleast the plastic ones are softer. im kinda in a rush for saw horses so building them is not quicker for me. but HAMLIN if you do decide to post them im sure it would help a lot of users in the same predicament. i might even build them in the future. thanks again shawn |
