| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User New Member | Helo all, I am just getting into sharpening, tried scary sharp, now on waterstones, like them, shaved a hair for the first time. I bought a Veritas honing jig markll, works well but just one problem. I set it up carefully and align the blade square, constantly checking it, but my bevels are never always square, sometimes they are slant and I can't find a reason for it. Any suggestions how I can control this problem? please say if you had this problem and how you worked around it. Guyos |
| | #2 |
| Registered User Forum Fanatic | Hi Guyos, Welcome aboard. I can think of 2 possible causes. 1. The jig is not true and square. I'm not that familuar with honing jigs, but check it to make sure that it is true. Even though it is new, it could be miss aligned. 2. You say you're using waterstones. Possibly your stones aren't flat. If you are starting with a course grit (800-1000) then working your way up to fine (8000), each stone has to be dead flat. If the iron in your jig is square to the jig, if the jig is true, and the stones are flat, then it should hone true.
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| | #3 |
| Registered User New Member | Thanks for the advice pop_pop1, I have aligned the blade properly in the jig, now I will try flattening the stones. I have seen the problem mentioned in other forums, but there dont seem to be a suggested cure for it. guyos |
| Lathe tool sharpening jig | curiousgeorge | Woodturning and Lathes | 4 | 01-12-2008 12:10 AM |
| "Free" tool from Amazon; help me select one | Ladd | Table-mounted Routing | 8 | 12-12-2007 10:54 AM |
| Neat Little Tool.... | challagan | Tools and Woodworking | 35 | 05-06-2007 11:48 AM |
| Monster HF Tool | BernieW | Woodturning and Lathes | 9 | 03-06-2007 04:25 PM |
| Tool Review Guidelines ~ READ BEFORE POSTING | Mark | Tool Reviews | 0 | 04-18-2005 12:31 PM |
