Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 02-20-2006, 01:30 PM   #1
saltysteele
Dedicated Member
saltysteele's Avatar
saltysteele is on a distinguished road
Default grease on machines
What does everyone use to remove the grease and oil on a new piece of equipment? I put together my jointer yesterday, and am scratching my head as to what the best thing to use, is. The bed and fence are covered in the stuff.
Thanks!
saltysteele is offline   Top - Reply with Quote
Old 02-20-2006, 04:20 PM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
I had a similar problem with my tablesaw. WD-40 worked, but the bit cleaner that came with the Boeshield T-9 kit worked pretty good as well. Used a white (ultra-fine) scotchbrite pad and most of it came off fairly easy. I'm sure that most any degreaser would work pretty well.
Enjoy your new toy!
1 John 1:9
Old 02-20-2006, 06:35 PM   #3
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Wd-40, or other "degreaser" works. However, once you remove the grease, it is suggested that you cover that machine with a wax of some sort to help prevent any rusting. Thus, why you have grease an oil on the machines.
Old 02-21-2006, 07:20 AM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: You can use kerosene or home heating oil to remove the grease> together with a scotch brite pad. The oil base will not cause rust but if you wipe off the oil then you should use a rust preventer,> Make sure anything you use does not contain Silicone,
as that will get onto your wood and screw up any finish you may use later. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 02-21-2006, 07:58 AM   #5
del schisler
Forum Geek
del schisler is on a distinguished road
get this kit it can be found at a lot of supplyers Boeshield T-9 kit
del schisler
del schisler is offline   Top - Reply with Quote
Old 02-21-2006, 06:55 PM   #6
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Plain old mineral spirits and a rag always worked well for me. A generious coat of Johnson's Furnature Paste Wax afterwards on bare metal. Nothing fancy, but it works well. Oh, I forgot......Elbow Grease.
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 02-21-2006, 09:41 PM   #7
CanuckBeaver
Sr. Member
CanuckBeaver's Avatar
CanuckBeaver is on a distinguished road
I've been rubbing my elbows on machinery for years, and they still somehow rust???
Sorry I couldn't resist.
I've sanded so much my fingerprints are gone!
CanuckBeaver is offline   Top - Reply with Quote
Best way to clean shipping 'grease' off new router bits? Gator95 General Routing 4 03-01-2008 08:59 PM
which machines? reds_21 Tools and Woodworking 1 01-10-2006 01:04 AM
