Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 02-28-2006, 10:16 AM   #1
routerjohn
New Member
routerjohn is on a distinguished road
Default Guide Rod Lubrication
On my table I am currently using a Craftsman 2 HP single speed plunge router. Recently I have encountered binding of the router and the guide rods. The owners manual does not mention any type of lubrication. The rods do have dust boots so there is very little dirt/dust. What would you suggest? I know if I use any type of grease, I open up the door for dust accumulation.
routerjohn is offline   Top - Reply with Quote
Old 02-28-2006, 10:31 AM   #2
jerrymayfield
Forum Geek
If there is no rust, clean the posts with alcohol or another solvent,apply paste wax and buff. Been doing it for years.
Regards
Jerry
Old 03-02-2006, 08:15 PM   #3
gcarroll
New Member
gcarroll is on a distinguished road
For previous posts on this forum a member suggested using STP motor treatment for your car engine. I have tried this just recently and it seems to work just fine. I cleaned the dust on the posts, dabbed my finger in the STP and applied it. Then I wiped it down so the post has just a thin film of this oil.
gcarroll is offline   Top - Reply with Quote
Old 03-02-2006, 09:08 PM   #4
reible
Supreme Forum King
reible's Avatar
Hi,
I'm the member who mentioned the STP... can't take credit for the idea, it came from the people who make the router razer. I have almost a year of using STP and I'm happy with the way it is working... I used the wax method for years but unless something changes my mind I'll now be a "STP" person.
Ed
Old 03-03-2006, 12:35 PM   #5
routerjohn
New Member
Thanks for the info. I tried the paste wax and that seems to work but if I try the STP, won't it attract the dust? Would WD40 work also?
Old 03-03-2006, 09:30 PM   #6
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
http://www.routertechnologies.com/in...man%20pack.PDF
I believe this is the link that Ed had posted in another thread for a similar problem. Well worth a read atleast.
Ken
Old 03-03-2006, 11:26 PM   #7
reible
Supreme Forum King
reible's Avatar
Yes it collects dust but the dust doesn't stick, you just wipe it away and add another light coating of STP (very light coating). I do this no more often then when I did the waxing and it is less work then waxing.
WD40 for all its good things is not a well suited for this application... For some fun check out:
www.wd40.com
You can sign up and get access to 2000 uses of wd-40 and other cool stuff as part of the "fan club".
Ed
Circular Saw and router guide "Off-set" plate simplenik Tools and Woodworking 9 11-19-2007 11:20 AM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 04:42 PM
Guide bushing identification Mike Guide Bushings and Templates 26 03-24-2007 10:57 PM
template guide and 1/2" collet pab Portable Routing 4 08-11-2006 07:59 AM
The use of template guides (Guide bushes) template tom Portable Routing 28 12-04-2004 09:18 PM
