lights on routers - Router Forums
post #1 of 11 (permalink) Old 04-02-2006, 03:27 AM Thread Starter
Rebelwork Woodworking's Avatar
First Name: Jack
lights on routers
Is there a reason router manufacturers dont add lights in their routers? I have an older B&D that is a favorite because of this feature.....Rebel
http://www.jackdurencabinets.com/homepage.htm
Rebelwork Woodworking is offline
post #2 of 11 (permalink) Old 04-02-2006, 12:18 PM
Hi Rebelwork
May be the reason is money.
Two weeks ago, I visited Japan and I saw a Makita trimmer with light (LED).
I assume that the models made for each country are a little bit different so please check it with “Makita USA”.
For the big routers, may be the assumption is that most of them are used under the table and in any case you don’t see what’s happening there, not to mention that most of the guys are using “insert” to close the gape so the light will not have any effect.
I saw the trimmer in operation at night and it’s really very nice idea.
niki
simplenik is offline
post #3 of 11 (permalink) Old 04-02-2006, 02:10 PM
labric's Avatar
First Name: Ric
Post
Rebel
I had a Craftsman router that I favoured and used for some 30 plus years that had a work light in the housing.
Needless to say when it worked, it was great, however most of the time the light bulb was burnt out and changing it was difficult, if you happened to have a spare bulb on hand.
I think the reason why more manufacturers don't include the work light is that it just doesn't work 100% of the time, as the vibration of the motor will destroy the bulb filament, plus the debris buildup inside the enclosed housing negated any value of having a light.
This same router ( which I still have ) also came with a single wrench and spindle lock system, to which has caused me just as much aggravation as the spindle lock has now broken away from the plastic housing on two separate occassions.
The first time this happened, Sears replaced the entire housing in order that the spindle lock functioned properly.
Since the last time this happened, this router has been delegated for cottage use only, and is still unrepaired, where it may still get some limited use, but with and extra wrench to tighten the collet.
Just my 2 cents worth.
Ric
Start Safe!!! Finish Safe !!!
labric is offline
post #4 of 11 (permalink) Old 04-02-2006, 02:13 PM
Rebel
I would say Vibration would be the big thing, most lights just can't take it on when they heat up.(light filiment thing)
The new LED type high power lights would need a low voltage power supply and that's to much weight to add with out a 2nd cord in the way,looks like battery types will take a big share of the market in the coming years and maybe they will offer the light opt. setup then, because of the battery is on the router. (DC power supply)
I did see a Norm's show (NYW) about 3 weeks back that had a sign maker showing how they made signs, he had a 50 watt spot light fixed on his small router to see the detail when he used the router free hand on a sign.
That was neat but a little Rube Goldberg set up but it worked for him on his open base router.
Just my 2 cents
Bj
post #5 of 11 (permalink) Old 04-02-2006, 02:28 PM Thread Starter
First Name: Jack
ive had the B&D router for many yrs. vibration and heat are not factors or i would have had to replace it already. either way it was a good ideal.
post #6 of 11 (permalink) Old 04-04-2006, 01:05 PM
awh
I think I have that same 30-year old Craftsman router you have! It has the micrometer adjustment instead of the screw thread arangement that most others use. I have also noticed that some of the current Sears Craftsman routers have LED lights... it might be a patent issue or something, if it's not I wish Porter-Cable would put a light on theirs it is a very handy feature.
Tony
awh is offline
post #7 of 11 (permalink) Old 04-04-2006, 01:25 PM
Gilbear's Avatar
I too have an older Craftsman with a light - not sure what year, but at least 10 yrs old - and wish the others had lights - my eyes are gettin' too old!! Never had much problem with it going out - maybe twice, but never used it that hard either.
Gilbear is offline
post #8 of 11 (permalink) Old 04-04-2006, 03:15 PM
Many Craftsman routers had the light feature. Skil was the first to use the new LED technology on a router.(As far as I know) People voicing their opinion is how changes are made to tools, so let your manufacturer know what you think.
post #9 of 11 (permalink) Old 04-04-2006, 09:40 PM
KENNETH KIDWELL's Avatar
I have a skill router that came in a kit with fixed base and plunge base and it has a light but the downfall is the base dont tighten down to moter and when you put a load on it the moter wiggles in its base I also have the sears router with light but the brushes have worn out
One good turning deserves another.
KENNETH KIDWELL is offline
post #10 of 11 (permalink) Old 04-05-2006, 08:28 AM
Gilbear's Avatar
A little off subject here, but speaking of need for good lighting, I remember an article recently, maybe in one of the shop magazines, about suggested light placement and guidelines for placement in shop design - I'll see if I can find it and post a link if anyone wants.
Gilbear is offline
Human Verification
2 Extra Routers What To Do With?? Steve B General Routing 17 02-28-2010 08:40 PM
Need 6 routers F3RR3T General Routing 14 10-21-2009 07:14 PM
Triton Routers DougO General Routing 32 11-17-2008 02:48 PM
New Craftsman Routers foleylink General Routing 2 11-11-2007 12:48 AM
.... echo of lights.... echo of lights.. presumed_druid Show N' Tell 5 03-23-2006 11:05 PM
