Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 06-06-2006, 10:56 AM   #1
Anniedog
Jr. Member
Anniedog is on a distinguished road
Angry Identify Stanley level?
I picked up a level at a garage sale over the week-end, I guess mainly cause it was only $1.
It is marked Stanley Mod. 233-24. It has unusual (to me) windows in that each window has TWO bubbles, and they will NEVER line up the same. Set it on edge on my work bench and one bubble will be dead on and the other will be way off, maybe even out of sight. I can see small arrows inside the window. The level is all metal and in pretty darned good shape, but It'll drive you nuts!! HA!
I suspect some of the old, bearded and toothless, gnarled and nasty, grim faced and worn members will have some familiarity with this tool and be able to fill us in on it.
As the acknowledged class slow boy.....I haven't a clue.
Anniedog is offline   Top - Reply with Quote
Old 06-06-2006, 11:59 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Anniedog
That's the way it should be.
So you can use it Vert. or Horz.
This type of level is called a contractors type (hvy.duty) and a real buy at one buck.
from one of the "the old gnarled and nasty, grim faced and worn out member"
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-06-2006, 01:56 PM   #3
awh
Member
awh is on a distinguished road
Okay, I fit about 50% of that description!
What you have is most likely a spirit level. It gets it name from the fluid used in the vials - mineral spirits, hence the term "spirit level".
If you look closely the vials are probably slightly curved, the main difference here is that the curvature determines the sensitivity and therefore eliminates the distortion that is associated with a straight (one that can be read 360 degree around) vial.
The curved vial generally provides a greater "accuracy" (not sensitivity) than the straight vial. The curved vial must be hand set, making sure that the crown of the vial is up, and must contain two vials in each location so that both working edges of the level can be used.
The straight vial is generally used today because it can theoretically be inserted in any direction around its circumference and should be accurate. This speeds the manufacturing process greatly, thus lending itself to the "economy" style of level so prevalent in all the “box” hardware stores.
awh is offline   Top - Reply with Quote
Old 06-06-2006, 02:04 PM   #4
awh
Member
Oops! Forgot to add that the small arrows you see inside the window point to the face that particular vial should be aligned with.
Stanley 82902 Router Base woodduck3 Introductions 7 08-20-2008 10:29 PM
Level Garage floor lablover Tools and Woodworking 28 07-10-2007 07:45 AM
Mystery Level Gets Worse!!! Birch Tools and Woodworking 3 06-25-2006 12:20 PM
Stanley Router No. 10 dunmovn Tools and Woodworking 3 09-14-2005 09:28 PM
