| | #1 |
| Registered User Sr. Member | The dust collection port on this plunge base is 1" inside diameter. I'd like to connect it to a shop vac hose when running the router by hand but what sort of elbow are people using to make the transition? There isn't room to use a straight adapter. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Paul A hose will do it most of the time, you can make a adapter(s) quick and easy with hole saw bits or you can get many adapters from Rockler ,most are not cheap like the ones you can make from stock you have around the shop. I use my plunge PC router on top of my router table most of the time in that way I can just plug in the vac hose that hangs from my light ,(see snapshots) I also have one on a PC that is a stantard adapter that works well when I use the MilesCraft tools.. I also let it hang over the router table when I use the brass guides to pickup the chips and that works great also. (see snapshots) The HOSE,,The boss had a old vac cleaner that I took the hose from, it's just the right size for most of my routers with a 1 1/2" out put. http://www.routerforums.com/attachme...achmentid=2889 http://www.routerforums.com/attachme...achmentid=2890 http://www.routerforums.com/attachme...achmentid=2891 http://www.routerforums.com/attachme...achmentid=2775 http://www.routerforums.com/attachme...achmentid=2485 Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 08-13-2006 at 10:56 AM. |
| Colt plunge base | bobj3 | Jigs and Fixtures | 19 | 04-01-2008 07:54 PM |
| Flat side of base plunge base | Noddy | General Routing | 2 | 09-11-2007 10:30 AM |
| anyone pull the springs out of a Porter Cable 890 plunge base? | paulcomi | Tools and Woodworking | 8 | 04-23-2006 05:26 PM |
| Pitting in PC plunge base | DONALD | Tools and Woodworking | 5 | 12-04-2004 10:36 PM |
| Converting fixed base to plunge base. | -Sam- | Portable Routing | 4 | 09-30-2004 03:53 PM |
