| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Dedicated Member | Some of the experts say to detension the bandsaw blade after you use the saw and retension it when you want to use it again. Does anyone have any comments about this? Gary |
| | #2 |
| Registered User Sr. Member | I have no idea if it helps or not, but I back tension off on my bandsaw 2 turns of the tensioning control if I don't intend to use if for 24 hours or longer. When I'm ready to use it again I just add the 2 complete turns. It's simple and doesn't take any time so why not? |
| | #3 |
| Forum Contributer Supreme Forum King | Hi Gary I would disagree with the experts on that one, hi tension steel once loaded that's it,it's not going to stretch anymore, break yes ,but that will happen when you over load it up. And removing the load after you use it will not do anything but make your job a bit harder when you want to use the saw. Some call it spring steel but that's just a gen'l.term because it will hold it's shape and taking off the tension will not change the blade dia. or make it last longer.Just my 2 cents Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-13-2006 at 08:58 PM. |
| | #4 |
| Registered User Sr. Member | In theory; the reason some manufacturers want the tension removed from the band is to keep the tires from deforming. Notice the word "Theory". The thickness of the wheel, the temperature, and the composition of the tires all play in, but I had never seen a wheel deformed from sustained tension. Michael |
| | #5 |
| Marine Engineer Forum King | It depends on how long you are going to leave the saw alone. Overnight, probably not a big deal. I would detension the saw if you are not going to use it for a long while. My Grizzly has a quick release tension lever, so it's no big deal to detension. Of course, just remember to re-tension it before you start it up..... makes a lot of racket!
| | #6 | |
| Registered User Dedicated Member | Quote:
Here's the problem: When I de-tension the blade, the next time I use it I forget to re-tension it so I'm not going to do it anymore. Thank you all for the comments. Gary | |
| New Bandsaw In The Shop.... | challagan | Tools and Woodworking | 23 | 10-22-2007 01:53 PM |
| Bandsaw Question | jarhead165 | Starting Off | 6 | 01-24-2006 07:47 PM |
| Mastercraft bandsaw opinions needed | BrianS | Tools and Woodworking | 8 | 11-05-2005 11:02 PM |
| Bandsaw advice needed | Bob | Tools and Woodworking | 7 | 06-07-2005 04:15 PM |
| New Hitachi Bandsaw | NewMontanaWorkshop | Tools and Woodworking | 11 | 04-05-2005 08:18 AM |
