| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Retired Moderator Forum King | Is it true that half inch shank router bits stay sharp longer than quarter inch shank router bits? I never heard of that. It sounds like it would make sense though. Bigger bit, more carbide, etc. Thanks! ![]() Last edited by -Sam-; 10-13-2004 at 01:59 PM. |
| | #2 |
| The Router Guys Forum King | It's good to see the tips are being noticed... 1/2" shanked bits have more mass than the 1/4" bits and with mass comes the ability to dissipate the heat build-up allowing the router bit to stay sharper longer.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Retired Moderator Forum King | Oh, okay. That's good to know. Makes a lot of sense. Thanks a lot! ![]() |
| | #4 |
| Router King Supreme Forum King | Think of a flywheel, the bigger the flywheel the more momentum.
__________________ |
| | #5 | |
"Making Tungsten Carbide Tungsten and carbon powders are blended and carburized in a furnace at 2700 - 2800 F. This produces the WC grains. These grains are combined with Cobalt powder and mixed in a ball mill. Tungsten carbide balls are mixed with grains allowed to run for several days to get even dispersal of the grains and the cobalt powder. This powder is then dried and wax is added as a binder. The wax holds the powder together and makes it somewhat slippery so it presses into shapes well. Typically 15 to 30 tons of pressure is used to form the carbide into a tool shape such as a saw tip. The parts are typically pressed one of three ways. They are rammed in a mold before sintering. They are isostatically pressed. Isostatic pressing means they are surrounded by a liquid or a gas and the pressure is applied to the liquid. This transfers the pressures to the surface of the parts uniformly. The third pressing method is hot pressing during sintering. The shapes are presintered in an atmosphere-controlled furnace at temperatures of 1,000 - 1,500F. The wax melts out and leaves the pieces sort of like a soft chalk. These chalk pieces can be easily machined although they are also easy to break and can be chipped here if handled improperly. The final step is another sintering step that can take place in a special atmosphere, a vacuum or both. The temperature is typically 2,500 - 2,700 f. During final sintering the parts will shrink up to 15% in any dimension and up to 35% in volume. " I have a feeling the heat issue is not going to hold up as a major issue in 1/4" or 1/2" shank court. At least in my opinion. I should also point out that carbide is often attached by way of welding or brazing both in the high heat areas compared to woodworking. My guess is if they last longer it is in the vibration/deforming areas. But hey what do I know? Ed | |
| | #6 |
| The Router Guys Forum King | As always there are many factors that make the sharp edges of Tungsten Carbide dull. Heat build up from friction, vibration, chatter, plus many other factors, which all translate directly into tool wear. Again, in my opinion: I find that my 1/4" shanked dovetail router bits will get dull sooner than my ½" shank bits. Thanks Ed for the great information on Tungsten Carbide.
| | #7 | |
Ed | |
| | #8 | |
| Registered User Jr. Member | Quote:
__________________ Sawdust Soozy “Not All Who Wander Are Lost..”-J.R.R. Tolkien | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 11:19 PM |
