The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page Special router bit
Special router bit
Tools and Woodworking Discuss Special router bit in the General Woodworking forums; Where can I find a upspiral router bit that is 3/32" in size. I have tried several distributers ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 09-05-2006, 05:44 PM   #1
pkowzan
User Info
Trader Rating: (0)
Gallery: View
pkowzan is on a distinguished road
Question Special router bit
Send Private Message | View Profile
Where can I find a upspiral router bit that is 3/32" in size. I have tried several distributers and they offer 5/32" or 1/4" which misses the whole point. I am working with material that is on 3/32" thick.
pkowzan is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 09-05-2006, 06:07 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Hi pkowzan
I'm almost sure you will need to drop down to a 1/8" shank size to get what you want.
Here's one web site for you to check out
http://www.grizzly.com/products/g7950
Below is just a standard 1/8" set,but no 3/32"
http://www.grizzly.com/products/h0880
Just a NOTE *** this is the router table I use when I use the small 1/8" size,it works great for the small ones
I also use my VS Dremel tool, when I run the router bits,the Dremel turns to fast and will burn the bits up otherwise.
see snapshots below... ▼
Bj
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/...op_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
bobj3 is offline   Top | Reply with Quote |
Old 09-05-2006, 08:50 PM   #3
Senior Moderator
Supreme Forum King
User Info
Trader Rating: (0)
Gallery: View
Country: Detroit, Michigan USA
Mike has disabled reputation
I doubt you will find an up-spiral bit. Bosch makes a 1/4" shank 3/32" bit, I have one. This is a single flute carbide bit. Check your local tool distributors to find one who carries Bosch or order online.
Mike is offline   Top | Reply with Quote |
Special router bit
Search this Thread:
Advanced Search
Router forums tall tails reible Lobby 11 03-03-2008 11:22 AM
Already Problems neuschu Introductions 7 01-22-2008 10:32 PM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
need special router bit mdd94 Tools and Woodworking 1 02-25-2005 01:26 AM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
