Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 10-13-2006, 12:48 PM   #1
oldnewbie
Forum Fanatic
oldnewbie's Avatar
oldnewbie is on a distinguished road
Smile Why Do I Need a Tablesaw?
I have a radial arm saw, band saw, scroll saw, and 2 routers. What can I do with a table saw that I can't do now? Everything I see talks about using a table saw. Am I missing something?
oldnewbie is offline   Top - Reply with Quote
Old 10-13-2006, 02:27 PM   #2
awh
Member
awh is on a distinguished road
I would think that if you needed a tablesaw you’d know it! A lot depends on the kinds of projects you do. I have a tablesaw, a radial arm and a miter saw... some might think it’s overkill, but to me they are used for different operations:
I seldom do miter cuts on the tablesaw, and never on the radial arm, this is the primary use of the miter saw, plus it's faster to setup... but the miter saw (as does the radial arm) have a crosscut limit, so in those instances the tablesaw is a must.
Dados and rabits are almost always done on the radial arm, but again there is a crosscut limit, so in those instances the tablesaw is a must (unless I’m using a router to do them!).
Sheet goods are always cut on the tablesaw... there’s no way to do those with a radial arm.
Tenon and taper jigs are used solely with tablsaws, but if you don’t do projects that involve those kinds of things then you’d never miss that ability.
Happy Woodworking!
Tony
awh is offline   Top - Reply with Quote
Old 10-13-2006, 06:24 PM   #3
JohnnyR
New Member
JohnnyR is on a distinguished road
A table saw is the safest for ripping...it can be done with a
RAS but the process is dangerous
JohnnyR is offline   Top - Reply with Quote
Old 10-13-2006, 06:56 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just my 2 cents
A radial arm saw can do every thing a table saw can do and sometimes a bit easyer and safer, most RAS can rip up to 26" wide, that's to say my saw can.
Some of the BIG RAS can rip at 46 1/2" and many of the big wood shops use a RAS /5HP 12" and 14" blades (see them at Tool King InterNet Web Site.)
It's a old 10" B&D /DeWalt made in the 60s,with a built in vac pick on the motor head unlike the table saw.
Ripping on a RAS is Safe, Most come with a hold down device (unlike most table saws) and a ant.kick back device all in the saw blade guard,but you must run the stock the right way under the guard,the hold down device will let you let go of the stock and move around a bit to grab the stock and pull it out and keep it true to the fence, I will some times use a guide block that's clamped to the top to get a true cut for cabinet /case work.
For a small shop the RAS is a good deal because of the small foot print.
And because the support head can turn and the saw motor can flip both ways it's a great tool for the wood shop.
Most are 120 volt unlike may of the high end table saws,the one I have can do a tri.compound cuts,that's to say the radial arm can move ,the motor head can move and the table I have has jig set up for one more setup.
I also have a router base bracket that bolts on the motor to help with the real hard router jobs.
http://www.routerforums.com/attachme...radarm-saw.gif
http://www.routerforums.com/tools-wo...g-madness.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-13-2006, 10:03 PM   #5
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Well as some one else here said it depends on the projects you do and your needs. I just don't think I could be without a table saw myself. Many do though and use the bandsaw for ripping but you have to have it set up right. Many folks use some of the new guided circular saw systems for ripping and they can now do repeated cuts and with a miter saw and router they just don't have a need. Bob Noles here sold his table saw and uses a guided system just fine.
I for one would never do a rip on a radial arm saw. I don't find them safe for much at all. To much can happen with climb cuts etc. on one of them beasts. For my box work that I do, I find a table saw to be needed and I use my Incra 1000se miter guage to do all miters. If it works for you to be tablesawless, it ain't broke so don't fix it.
challagan is offline   Top - Reply with Quote
Old 10-13-2006, 10:22 PM   #6
cranbrook2
Supreme Forum King
cranbrook2's Avatar
cranbrook2 is on a distinguished road
I use a tablesaw sometimes for 8 hrs at a time.
i couldn,t imagine not having one.
john in cranbrook ontario.
(plans)
www.extremebirdhouse.com
cranbrook2 is offline   Top - Reply with Quote
Old 10-13-2006, 10:39 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
Just today I was using the RAS to cut some setup blocks for a new tool (Katie dovetail jig, KJ-1) http://www.sommerfeldtools.com/products.asp?id=164
the blocks are 1/2" x 1 1/4" x 2 1/8" MDF and I needed to put in a dado slot that was 3/16" wide and 1/4" deep and a dado slot on the back side that was 7/8" wide and 5/16" deep this type of job was to small for the router or the table saw, so I did it on the RAS because it's easy and quick and safe because my hand is not moving over the blade or by it other than the handle on the RAS.
It's the only saw I have that I feel safe cutting small parts on, but it could be I have use it for so long.
But I do use hold down sticks when I need to cut with in 1/2" of my hand,but if I need to get down and dirty I will use the band saw.
Like Today I had to make some parts out of Alum. stock for a mate on the band saw ,that was a hard job, I had to use a Alum. block 2" x 2 1/2" x 3" and cut 5ea. L- brackets 3/16" wide x 1/ 5/8" long legs x 5/16" thick .
But you're right if the RAS is not your cup of tea it should not be used.
Have a good one mate
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-14-2006, 12:44 PM   #8
challagan
Supreme Forum King
challagan's Avatar
That's right Bj, if you are afraid or not comfortable with a tool you shouldn't use it. I try not be get to at ease with any tool cause they all can reach out and bite you at any time but you do have to have a certain "comfort" zone with a tool. Have a good one.
corey
Old 10-27-2006, 06:21 PM   #9
Lee Brubaker
Forum Fanatic
Lee Brubaker is on a distinguished road
I don't own a TS & have no desire for one. I bought my RAS new in 1958. It is a DeWalt built by American Machine & Foundry. A 1 hp 120/240 volt motor using a 9"blade. I rip without difficulty sheet goods or anything else my heart desires. I no longer do mouldings using instead my router table for this duty. I have a CMS that is on a wheeled,collapsible stand that leans against the wall out of the way. It was a gift. It has a universal motor & I do not like the sucker up next to my head howling away despite ear protection. Damned things should be banned for that reason alone. Those who are frightened by an RAS are often people who have never owned one & need to take what TS owners say on forums with a grain of salt. There is one operation that is dangerous: Namely ripping without the kickback device in place & then during the rip process, the piece walks away from the fence, the operator then reaches with his left hand to push the work back to the fence, the work pinches the blade & as a result, kickback, which takes the operator's hand into the back of the blade....the operator now has no left hand.
I still have everything that I was born with & a good reason being
that when I bought the saw, I also bought AM & F's book on proper safe operation of the saw.
I too hang a router on my RAS....& with a turntable, makes it easy to machine polycarbonate bit inserts for the table insert in my router table.
I also have the sabre saw attachment for the RAS. Comes in handy because I do not have a jig saw.
9" blades are becoming difficult to acquire. Fortunately Freud still make them in Italy & it is a quality blade at a reasonable price.
Lee
Lee Brubaker is offline   Top - Reply with Quote
Old 10-27-2006, 08:13 PM   #10
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Pending on what type of "job" you need it for. As has been stated above, not every tool is for every person. I prefer to use a TS for ripping extremely large pieces. I use my miter saw for smaller pieces. Again, personal preference and the most important, what you are most comfortable with using.
Ken
"A VETERAN"
Jet Tablesaw extension with Jessem RouterLift System A-Pat-Co Table-mounted Routing 8 04-11-2007 09:54 PM
Tablesaw RustyW Starting Off 5 10-12-2006 08:45 PM
Rippin plywood with Tablesaw ShaneB Starting Off 6 01-18-2006 12:42 AM
Tablesaw blade guards delroy33 Tools and Woodworking 22 12-31-2005 06:17 PM
New tablesaw Julie Tools and Woodworking 6 07-24-2005 08:17 PM
