Attaching Hinges To A Jewelry Box - Router Forums
post #1 of 17 (permalink) Old 03-15-2012, 11:10 AM Thread Starter
First Name: Jerry
This subject is probably very basic to even a moderately experienced woodworker. Here is a description of the issue. After the top has been cut off of a jewelry box it is time to install hinges. At this point, as I see it, I have three options. First, the simpilest thing to do is to simply install the hinges flat on the outside faces of both the top and the bottom of the box. This leaves the hinges raised above the surface of the back of the box. This does not require much expertise. The next approach would be to cut recesses into the faces of the area where the hinges reside, and the third would be to cut the recesses into the top edge of the bottom part of the box and matching recesses into the bottom edge of the top of the box. This will cause only the barrels of the hinges to be visable when the box is closed.
Cutting the recesses is where the rub comes in of course. i have tried several appraches to this but so far I have not found a method that really works well for me.
When cutting the recesses into the edges of the top and bottom of the box with a straight bit was my first approach. What happened was that the bit would cut a nice clean cut edge on the side of the bit that rotates into the wood as it is fed into the bit, but on the other side of the bit where the cutter is going with the feed, the cut is less than desirable, by that I mean that the cut is not clean and sharp. This can be remeied by doing a complete new set up for the other edge of the cut, but doing this becomes very tricky, or at least it has for me.
When I have tried to cut recesses into the faces of the back and top of the box, I have used a one eighth inch straight bit with stops on the fence to restrict the cutting area, but getting the cuts on the bottom and the top of the box to match perfectly has caused me to scratch my head. In other words, cutting these recesses has proved to be a real challenge. I suspect that I can eventually figure it out, but I am just wondering if anybody has any ideas that would shed some light on this subject.
Jer
Jerry Bowen is offline
post #2 of 17 (permalink) Old 03-15-2012, 11:47 AM
Hi Jerry
You may want to think about using barb hinges, they come in many types, and are very hard to see once they are in place and very easy to put in place in the Jewelry Boxes.
Brass-Plated Small-Box Spring Kerf-Cut Hinge - Rockler Woodworking Tools
http://www.rockler.com/tech/RTD10000246AA.pdf
http://www.rockler.com/product.cfm?page=18652&rrt=1
http://www.grizzly.com/products/Slit...aw-Arbor/G1438
post #3 of 17 (permalink) Old 03-16-2012, 09:06 AM
Honored Member
harrysin's Avatar
First Name: Harry
Perhaps these shots from earlier posted projects of mine might give you some ideas.
Harry
harrysin is offline
post #4 of 17 (permalink) Old 03-16-2012, 10:09 AM
Gene Howe's Avatar
First Name: Gene
Some folks will cut the box edge deep enough to accept the closed leaf, thereby negating the need for aligning a cut in the lid.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 17 (permalink) Old 03-16-2012, 10:16 AM Thread Starter
First Name: Jerry
Hi Harry,
Thanks for your help, the photos do help, mostly verifying that I am on the right track. Much like so many things, you have to figure out a method that works for you and then just stick with it. I tried several different approaches over the past couple of days and while the end results were close, none of them made me happy, so, today I have one more idea that I want to try.
In regard to the hinges, I have purchased quite a few sets of small simple hinges from Rockler that I want to use because I have them, but when I get to a point that my jewelry boxes really look like I want them to look, I may try the hinges that you have suggestged, they look good, but are a little spendy unless they are used on a nice project. Again, thanks for your help and interest in helping me.
Jerry
post #6 of 17 (permalink) Old 03-16-2012, 10:59 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by Jerry Bowen View Post
Hi Harry,
Jerry
Yes, piano type hinges can be pricey, especially the type shown which only open about 95°, however not too long ago I was on one of my regular visits to our local salvage yard when I came across a box full of these 4 1/2" hinges at, I'm pretty sure, TWENTY CENTS EACH! Not being greedy, and bearing in mind my age, I only bought 20.
In case it wasn't obvious in the photos, I do what Gene suggested in his post, that is a double depth rebate in the box and mount flush on the inside of the lid. I also make the lids a little oversize in case of minor errors and then trim them on the router table. The second shot shows how I routed the carcass for a square ended piano hinge
Harry
harrysin is offline
post #7 of 17 (permalink) Old 03-16-2012, 11:53 AM
papawd's Avatar
First Name: warren
Very nice Harry, I always like Your pictorals it is like getting a free woodworking lesson
papawd is offline
post #8 of 17 (permalink) Old 03-16-2012, 01:24 PM
just one more way
post #9 of 17 (permalink) Old 03-17-2012, 10:17 AM
Honored Member
harrysin's Avatar
First Name: Harry
Thank you Warren, but that is what this forum is all about, helping fellow members and personally I firmly believe that a picture is worth a thousand words, often I fail to understand posted explanations, however, I'm sure that a few photographs in all cases would have solved the problems.
Harry
harrysin is offline
post #10 of 17 (permalink) Old 03-17-2012, 10:18 AM
Honored Member
harrysin's Avatar
First Name: Harry
just one more way
Another worthwhile idea Bob.
Harry
harrysin is offline
Human Verification
My first box dkneifel Show N' Tell 19 02-08-2016 09:10 AM
Belated anniversary jewelry box Ghidrah Show N' Tell 14 07-04-2010 04:47 PM
Jewelry box part one Ghidrah Show N' Tell 10 12-03-2009 06:40 PM
Best wood/ grain hiding technique for jewelry box top rstermer The Finishing Touch 3 05-03-2008 12:57 PM
