| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Supreme Forum King | has anyone used the Osborne EB-3 miter gage. I have been looking at diffrent after market miter gages any place from $100.00 to $250+, not that i want to spend that much for a miter gage but. the osborne is about $165.00 and before i was to spend that much i was hopeing i could hear some positve and negitve comments about this gage it would be a big help. thank you for your help. ![]()
__________________ roy ![]() start square, finish square |
| | #2 |
| Registered User Forum Geek | Hi: I have the ACCU MITRE, Ihave had it for years and it is quite accurate. I don't think that the Osborne could be any better. It is priced a little higher, but I can't see it being all that much better. Hope this helps you out. Woodnut65 |
| | #3 |
| Router King Supreme Forum King | Look into the Incra 1000 it is priced under $100.00 and is supposed to be rated highly.
__________________ |
| | #4 |
| Registered User Jr. Member | I have and Osborne, and was quite excited when it arrived. However, I found that it is somewhat awkward to use, and probably wouldn't spend the $'s on it if given the choice a 2nd time around. It really depends on what you need a "souped up" miter guage to do. As far as cutting accurate miters, I've found with experience that an accuract drafting angle, or protractor, can be used to set the angle on the miter guage that comes with most good table saws (mines a Unisaw). If you need a longer bearing surface to push the piece through the blade, simply fasten a scrap of plywood or hardwood to the miter guage using drywall or Vix screws. Then take it off when you're done. If you're looking for a "souped up" miter guage to provide more accuracy on standard crosscuts, save your money and instead build crosscut boxes in several different sizes. I'm only guessing on why you think you need an expensive aftermarket miter guage, but thought I'd share my practical experience with you. Hope it helps. |
| T-Track vs. Miter Channel | Paul3624 | Table-mounted Routing | 7 | 01-23-2008 01:30 PM |
| Do you use a mitre gauge on a table? | neoshed | Table-mounted Routing | 10 | 11-01-2007 09:32 PM |
| What miter gauge do you use? | jdmyers4 | Table-mounted Routing | 14 | 05-23-2007 09:42 PM |
| Miter gauge | AxlMyk | Tools and Woodworking | 7 | 03-06-2007 07:36 PM |
| Table Saw Miter Guage Fence | dunmovn | Tools and Woodworking | 3 | 12-11-2006 03:21 PM |
