Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 11-19-2006, 08:41 PM   #1
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Default Barbed Hinges...
Does anyone here have any experience with the barbed hinges and the saw blade and arbor that cuts the slot for these? Just curious as to how well they work. I see they are avialable from Woodcraft for about 40.00 for the arbor and blade. I think they are designed for the drill press. I read in one of Doug Stowes box making books that he uses one in a router table and uses a jig. Just curious what you guys think of them.
challagan is online now   Top - Reply with Quote
Old 11-19-2006, 11:47 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
I have not used them but it looks a bit tricky to put them in with chamfer and the rabbet cut that's needed to hide the barrel of the hinge and to let them fit right so the top will close all the way.
http://www.woodcraft.com/family.aspx?familyid=3744
But if you give it a shot please post what you think of them.
Have you tried Bob and Ricks way to put in small hinges and the small piano type.
It's quick and easy and it hides the barrel with one pass of the router bit.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-20-2006, 08:33 AM   #3
challagan
Supreme Forum King
challagan's Avatar
Bob I am considering buying a set up or maybe Santa will I am not a fan of piano hinges myself. What do they do on small hinges. Must of missed that.
corey
Old 11-20-2006, 10:57 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Corey
Once you have the box made and you have cut the top off ( with a slot cutter,band saw,router bit,etc.??) tape the box back up on 3 sides(with masking tape works well), chuck up a 1/4" solid carb. bit in the router table ,close the hinge and this is the height you want to use to set the bit height,then set the box on the table and move the fence so the bit will go into the space in the top and bottom,now for small hinges put some masking tape on the fence and mark it with the start and stop points you want the hinges to be on the box,then drop and plunge the bit into the box,then remove the tape and install the hinges.
If you have REAL small hinges (real thin ones) just use a smaller router bit,works great.
If you have a sq.end hinges just take a sharp knife and sq.out the corners.
Don't use a chisel, it will compress the wood in the corners and it time it will lift the hinges when it comes back in to place unless you use a REAL sharp chisel.
Just a note,,,,I use stop blocks on the fence inplace of the masking tape because it's dead on unlike the eye ball way (masking tape) and this is the last step in making a great box and the 2nd. thing someone always looks at.
B/4 you use this way find some scrap stock and tape it up and give it a test run you will like it because quick and easy and it looks great when your done.
Do it on two sides with the grain and across the grain this will give you the look of both.
Just a side NOTE***
This type of slot cutter works great for cutting the top off the box, 1/4" shank and use it without the bearing just with a small O.D. washer (SAE type or ANS) that's the same dia. as the lock nut. (2 or 3 of them)(the norm 1/2" O.D. nut,many router bits come with the small OD washer) and the router table fence.
http://www.mailwareweb.com/sommerfel...scb3a&d=75&b=1
Hope this helps
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-20-2006, 10:04 PM   #5
challagan
Supreme Forum King
challagan's Avatar
Thanks Bob for the info!
corey
Old 11-20-2006, 10:41 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You're Wecome Corey
Once you give a try let me know what you think
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Need help mortising hinges johnt Guide Bushings and Templates 11 04-27-2008 11:42 AM
Help with Hinges nzgeordie Tools and Woodworking 6 12-07-2007 08:32 AM
vers SMALL hinges reds_21 Tools and Woodworking 1 08-13-2005 09:51 PM
Hinges, locks on small pieces? Densa Jigs and Fixtures 4 01-27-2005 01:23 AM
