Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 11-21-2006, 11:11 AM   #1
rprice54
Sr. Member
rprice54's Avatar
rprice54 is on a distinguished road
Default any fix for a drill press?
I have a 10" craftsman drill press that's just under a year old. One time while using a spade bit (at too high of a speed setting I've now learned) the bit caught on a knot and the chuck came off the quill. It's a tapered quill and you just tap the chuck onto it. I cleaned it out and reset the chuck, but now it has considerable runout/wobble, to the point where it's almost un-usable. I've reset the chuck twice without any improvment. I think the quill is still true (at least as true as a cheap drill press can be) but I can't seem to get the chuck on straight.
do you think the chuck could be damaged? I really don't see how, but I'm tempted to take it in to sears to see if there's anything they can do with it, or try a new chuck on it.
any suggestions?
rprice54 is offline   Top - Reply with Quote
Old 11-21-2006, 12:03 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi rprice54
It's Not the chuck
Most of the drill press use a morse taper that the chuck slips on. BUT it must be true and clean, no marks,on the chuck or the shaft.
Most have a nut on top of the chuck but some don't some have a key bar the you tap in the shank/arbor of the press to remove the check arbor shank.
But the bottom line is you need to remove the chuck and with some 600 grit or 800 grit paper clean both parts, once you have the parts clean, NO marks inside or out, move the table to one side and get a hard wood block and some WD40 and drive the chuck back on, it will take a sharp hard blow to set it in place.
Besure to have the chuck open to the max DON'T hit the chuck with any metal tools top or bottom of the chuck, it will damage it and it will become junk.
You must take care when you work on the chuck it's like a big watch and made the same way.
If you need to tap on the chuck use some hardwood and cut it so it fits the main part of the chuck NOT the outside ring just the main body.
It also needs a sharp blow to get it off
Also don't over clamp it in the vise use your wood vise if you have one or some wooden blocks for this job,they are made of high end tool steel and will snap like a walnut nut...
Just a small note**** this is quick way to check the shaft out,if you a maget around take a metal rod put some elec.tape on one end then place the maget with the rod on it, place it on the drill press so it can just touch the shaft, turn the pulley by hand and view the end on the rod, should NOT be a gap at any point, if so take it back to Sears for a replacement.
Hope this helps
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-21-2006, 09:33 PM   #3
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
RP, I have a sears floor model drill press and I've had to change out the chuck due to a similar problem. You model most likely has a tapered chuck. Some of these tapers will slip inside a notch inside the quill. Make sure this lines up before "tapping" it in place.
Ken
"A VETERAN"
Need info Chicago 5-speed drill press Birchwood Tools and Woodworking 14 10-22-2008 04:10 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 12:20 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 11:43 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 10:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 10:03 PM
