| | #1 |
| Registered User Dedicated Member | I am attempting to build some XMas presents and am attempting to do some inlay. I bought a couple of 1/8 spiral bits and have been working with Maple trying to cut a simple little 1/8 by 1/8 groove. I have broken two bits so far. I have gone slow and tried to be gentle. What am I doing wrong? |
| | #2 |
| Registered User Supreme Forum King | I've broken I think 3 bits in the last couple of years. One was a 1/2" stg bit I dropped and TWO 1/8" spiral bits. Both times I think I was trying to take to deep a cut, in both cases it started to vibrate but before I could do anything else they broke. Each time I went back and finished the project using a new bit and lighter cut. If anyone else has any ideas please let us know, I think I payed about $14 each for those....... Ed |
| | #3 |
| Registered User Dedicated Member | I suspect either too fast a cut or too deep a cut, or a combination of both. I use an 1/8" solid carbide spiral bit to cut splines out of caning every few days. Too fast or too deep and they break off every time. The last one I've been using for over a year without any breakage. |
| | #4 | |
Also would you mind tell us who makes the bit(s) you use? If you would rather not say that is OK too. Thanks for the responce, Ed | |
| | #5 |
| Registered User Forum King | Increase the speed of the cutter and reduce the speed of cutting. Tom |
| | #6 | |
| Registered User Forum Geek | Quote:
Hope this helps, Woodnut65 ![]() | |
| | #7 |
| Registered User Dedicated Member | Ed First off, if the spline comes out without effort, that's the best way. Otherwise you want to cut through the old spline so you can get it out with a minimum of damage to the piece of furniture. I use a cutout tool like this http://www.harborfreight.com/cpi/cta...unction=Search Get a 1/8" spiral carbide bit (I like using the 1/8" shank bits). I've gotten them through Grizzly, no complaints there. First take an exacto knife to cut along both sides of the spline to seperate it from the wooden frame. I start off with the bit set about 1/8"-3/16" exposure. Start in one corner and carefully control the tool as it has a tendency to pull if you're not careful. Once you're gotten it around, use a chisel and peel some of the spline out. Lower the bit and go around again, cutting deeper till you cut through the old spline. Once it's cut through, if it comes out easy, so much the better. If it doesn't pour a little white vinegar into the slot you've cut and let it soak a while. It will loosen up the old glue. Take an exacto knife and cut an X from corner to corner through the old cane. Peel the old cane back and it will usually come out fairly easy. I use a sharp chisel, a commercial spline removing tool and another one I made specifically for the work I do. I have used this in redoing probably 200+ cane panels over the last few years and as the saying goes: "It works for me". You need to use care with the cutout tool. It wants to pull to the side if you're not careful. Working counter clockwise is best, if you slip, it cuts to the inside of the spline groove. I brace it carefully with one finger hooked over the edge of the piece. You have to determine your own speed, too slow and it can burn (as in smoldering) and too fast or deep and you break the bit. Then it's a matter of putting in the new cane, staining and sealing it and you're done, but that's another story. By the way, is you need guidance in how to install the new cane, shoot me an email. Pauol Last edited by hcbph; 10-30-2004 at 11:51 PM. |
| | #8 |
| Registered User Dedicated Member | The first one was a Freud bit, the second one was a cheaper one. The Freud one did last longer, unfortunately, it's hard to get to the shop that carries those to replace it as I usually seem to break them on a Sunday ![]() |
| | #9 |
| Registered User Dedicated Member | I just noticed that shortcut I posted was no good. Try http://www.harborfreight.com/cpi/cta...emnumber=42831 Any cutout type tool with a solid, adjustable base and preferably with both a 1/8" and 1/4" collet is good. The smaller the base, the closer it can get to other pieces ( eg. caning a back on a chair that is close to the seat rail). You can use a laminate or other router, you just can't get in a s close to those restricted area around rails or arms. |
| | #10 | |
I will print up these measages and then when I feel up to it I'll get the chair down and see if I get lucky or not. By the way do you disassemble the chair to get at the seat? And if the seat and back are the same age should I also replace the seat back while I'm at it? Ed | |
| Spiral Bits/splinters | George II | General Routing | 5 | 01-29-2008 10:50 AM |
| Spiral up or spiral down | slumlord | Introductions | 6 | 12-14-2007 12:54 AM |
| spiral bit | woodendigits | General Routing | 2 | 09-03-2006 11:15 PM |
| Sharpen a spiral bit | fade2black | General Routing | 6 | 01-05-2006 11:04 AM |
| Bit problem - using spiral bit in a table | Matt | General Routing | 4 | 11-23-2004 08:02 PM |
