Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 12-30-2006, 05:11 PM   #1
simplenik
Forum Geek
simplenik is on a distinguished road
Default Triangle - "Copy" and "Past"
Good day
I have a big accurate (it better be for $15) 45° drafting triangle.
To save it, I Copied and Past it to plywood triangle.
If you copy it to 1/2" or 3/4" and make 2 slots for clamps, you can use it as "square holder" during carcass, box or frame gluing
Happy New Year
niki
simplenik is offline   Top - Reply with Quote
Old 01-01-2007, 04:08 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
A nice idea for home made glueing jigs. Rockler Woodworking has some small assembly squares made from a plastic that glue does not stick to. They make these in two sizes and have a new set that is angle adjustable. They call these jigs "Clamp its" and they also have special miniature F style clamps designed to fit them.
Old 01-01-2007, 05:42 PM   #3
simplenik
Forum Geek
Thank you Mike
When I made it, I did not mean to use it for gluing.
After I made it I thought that if I copy it to 1/2" or 3/4" and make slots for the clamps, it can be used also for gluing.
I forgot to mention that, in this case it's better to remove part of the apex, so it will not touch the glue squeeze-out at the carcass corner.
niki
Old 05-28-2007, 06:01 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
I've been seaching for BIG triangles...
I've found 12" ers... and 14" ers...
http://www.draftingsteals.com/21259.html
http://www.draftingsteals.com/20188.html
http://www.draftingsteals.com/20199.html
http://www.draftingsteals.com/20210.html
Just how BIG is your BIG triangle??
While you're at it, what is the thickness?
Thank you...
Joe Lyddon is offline   Top - Reply with Quote
Old 05-30-2007, 01:05 AM   #5
simplenik
Forum Geek
Hi Joe
The "leg" (Cathetus) is 32 cm (around 12½") and the long side (Hypotenuse) is 45 cm (around 18").
The thickness is 1/8" (3mm).
You can easily enlarge the triangle during "copying" on the router table.
If you want to be sure that the router bit cutter will not touch the plastic... when you screw the triangle to the plywood put some washers or spacers between the triangle and the plywood.
niki
