Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 01-02-2007, 01:52 PM   #1
Julie
Forum Geek
Julie's Avatar
Julie is on a distinguished road
Question Stripped screw
Hi, I haven't been here for ages, but wish everyone a Happy 2007, full of wood projects that go smoothly!
My question is... how do I get a stripped brass screw out of my router base plate?
Thanks,
Julie
Julie is offline   Top - Reply with Quote
Old 01-02-2007, 02:37 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Julie, there are a couple possibilities. If it is a phillips head screw and not completely gone you can wet the tip of a phillips screwdriver and stick it in a can of cleanser. Push the screwdriver firmly into the screw and the cleanser will give you enough purchase to remove the screw. If the screw is a flat head and you can get at it you might be able to cut a new slot using a Dremel type cut off wheel. If the screw is broken off below the surface you will need to drill the center out and use an extractor. These are available from Sears and most hardware stores and are specific to your screw size. A set is usually under $10. After drilling with the proper size bit you tap the extractor in lightly with a hammer and use a wrench to turn the screw out. If the threads are damaged in the router base you can purchase a Heilicoil brand kit with a special size drill and an insert you screw in to restore the threads. One of these should work. If not let me know.
Old 01-02-2007, 03:18 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Julie
Just some more ways to get it out
Take a GOOD screw driver and place it on head ,on dead center of the screw and then strike the screw driver,this will drive the screw down just a bit,but you must hit it hard,BUT not to hard you don't want to break the base.
They make may tools to get them out, the one I use all the time on ALum.bike eng. looks like a hvy. punch that you put in driver bit,when hit the tool it that turns the screw just a bit and will free it.
ABout a 10.oo dollar item at the auto parts store.
IMPACT SCREWDRIVER SET WITH CASE
http://www.harborfreight.com/cpi/cta...emnumber=37530
Here are some other tools to get it out but a sharp blow should do it.
Here's a fast, easy solution to stripped screws.
Just insert one of these super-tough drivers into the screw head, give a couple of taps with a hammer, and twist free. Chrome vanadium blades are specially designed to bite into almost any stripped head.
Steel-butted drivers with unbreakable vinyl grips.
Includes one Phillips and one slotted driver.
http://www.harborfreight.com/cpi/cta...emnumber=38037
Craftsman 3 pc. Screw-Out™ Damaged Screw Remover Set
http://www.sears.com/sr/javasr/produ...id=00952154000
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-02-2007, 10:56 PM   #4
simplenik
Forum Geek
simplenik is on a distinguished road
Hi Julie
You did not give much information so, assuming that it's one of 3 or 4 screws that are attaching the base plate to the router...
I would carefully drill out the screw head, unscrew the rest of the screws and remove the base plate and than, using "wise grip" unscrew the stubborn screw.
Hope it helps
niki
simplenik is offline   Top - Reply with Quote
Old 01-03-2007, 11:15 AM   #5
Julie
Forum Geek
Julie's Avatar
Thanks for suggestions.
My husband does have one of those remover/punch thingys but I was worried that would crack the base plate of the router. (Hitachi M12V router with Oak park black base plate)
~Julie~
Old 01-03-2007, 12:28 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi ~Julie~
Just put a 2 x 4 in the vise to support the router base b/4 you hit it.
You may need to bandsaw the 2 x 4 to get it in and under the base.
It maybe worth the time to make a quick jig to hold the router.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Delta Quickset II Blade Clamp screw- holddown screw rstermer Wood Scrolling 2 09-25-2008 11:21 PM
Delta P-20 Material Holdown Clamping Screw rstermer Wood Scrolling 6 06-10-2008 07:27 PM
Craftsman scroll saw part? Birch Wood Scrolling 6 11-17-2007 03:47 PM
Making Screw Clamps rmaxa Tools and Woodworking 11 08-13-2007 12:11 AM
How To Destroy Screw Heads cabinetman Lobby 4 06-09-2007 07:03 AM
