Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 11-13-2004, 11:03 PM   #11
Bluegillman
Jr. Member
Bluegillman is on a distinguished road
True, it speeds the work up with those pocket jigs. I have a homemade pocket jig and it does work great. They do move a little, I clamp them tight with one another and flat, it helps. But what's the hurry? I stick with those dowels and and it doesn't move while I glue and clamp.
Bluegillman is offline   Top - Reply with Quote
Old 04-10-2006, 08:42 PM   #12
ShaneB
Dedicated Member
ShaneB is on a distinguished road
Has anyone used the CMT pocket pro and if so how does it compare to the kreg?
ShaneB is offline   Top - Reply with Quote
Old 04-11-2006, 09:36 AM   #13
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Clamping and stop blocks are the right answer Ed. Always use glue in the joints unless you are attaching a removeable panel for easy access or a table top. Here is a simple tip to get great results when attaching table legs to the aprons(side pieces) on a shaker style table:
Figure out what you want your inset to be on the aprons, say for example 1/4". Use your router to cut a 1/4" deep rabbit or rebate the width of the leg on a piece of scrap wood that is about a foot long. Clamp it to the leg with a mechanical clamp.(I use Quick grip bar clamps) Position your apron and clamp it to the scrap wood, drill your pocket holes and then remove the clamp from the apron only. Apply your glue to the apron only and run your screws making sure to not over tighten and strip the holes out. This simple jig ensures all your joints are identical and you get almost no movement this way. Pocket hole jigs are great for attaching table tops too.
Kreg system opinions? Birch Tools and Woodworking 14 04-06-2008 04:52 PM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 5 01-21-2008 09:14 AM
Finger Joints J0B00 Jigs and Fixtures 18 08-24-2007 03:19 AM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 11:20 AM
finger joints ron dwyer Tools and Woodworking 3 11-28-2004 12:44 PM
