Rate This Thread - Punching Holes in Sandpaper.
Thread Tools Display Modes
Old 01-03-2007, 03:53 PM   #1
beemerbob
Member
beemerbob is on a distinguished road
Default Punching Holes in Sandpaper
I have a Bosch 1297 quarter sheet sander and a lot of regular sheets of sandpaper.
Is there a better way of putting holes in the sandpaper for the dust collector?
Bob
Bob from Northwest Florida
beemerbob is offline   Top - Reply with Quote
Old 01-03-2007, 04:22 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Bob
I use a gasket punch set, you can find them at most auto parts stores or HF.
The set I have that has 12ea. from 1/8" to 3/4" I have added over the years 7/8" to 2" and I have made one or two with some steel tubing, thin wall , by grinding one end to a sharp knife edge and put in a wooden dowel in the open end, they work well also.
All you need to use them, is put the gasket/sand paper of some scrap wood and strike the punch and the hole(s) comes out clean.
I now save big time on sanding disk that have the holes in them by buying the uncut stock from Grizzly and make my own.
http://www.harborfreight.com/cpi/cta...temnumber=3838
http://www.grizzly.com/products/g9845
http://www.grizzly.com/products/H3329
Hope this helps
Bj
bobj3 is online now   Top - Reply with Quote
Old 01-03-2007, 11:27 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Bob, I have seen a jig that speeds the process of punching the holes. You trace the hole pattern onto a block of wood and drill the proper size holes and repeat the process onto a 2nd block and install dowels. This gives you a punch and die so one hit cuts all the holes. The holes will not be as clean as with BJ's method but will get the job done quickly.
Old 01-04-2007, 07:34 AM   #4
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
My quarter sheet sander(mental block, can't remember the brand for some reason) came with a plastic jig to do this. Install the sheet, and then place the sander in the jig and it punches the holes thru. I like the idea of an external method tho, as I've occasionally had to clean pieces of sandpaper out of the holes in the sander.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 01-04-2007, 10:16 AM   #5
simplenik
Forum Geek
simplenik is on a distinguished road
Hi Bob
Have a look at the post "Sanders modification"
I got rid of those holes long time ago
niki
simplenik is offline   Top - Reply with Quote
paper template to position plate drill holes NatureMan Starting Off 2 01-22-2008 03:51 AM
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 7 12-30-2007 06:18 PM
Boring 5mm Holes for Shelf Pins garycurtis Router Bits - Types and Usage 4 12-20-2007 05:38 PM
Misaligned holes in phenolic plate jrs4464 Introductions 1 08-08-2006 07:18 PM
Bench dog holes Bob Tools and Woodworking 10 02-18-2005 11:23 AM
