| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User New Member | Hi I am new to the site and I was wondering if you can get the same results from a router instead of a jointer. I puchased a 6" table top but havn't opened it yet and I am wondering if I should just return it and try to get by with my router and table. Thanks Tim |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Tim The router can do many jobs but if you have a new jointer keep it ![]() It can do so many jobs when you get into wood working and you will wish you had one. e.g. put on a nice clean edge on a 4ft long board, sq.out some 4" x 4" for legs,sq.up stock b/4 you but on the table saw,etc. I should note most wood is not true when you get it from lumber yard,HD,Lowes or if you store it for a bit,it's always moving out of shape,until you nail it,screw it or glue it down.Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-11-2007 at 08:13 PM. |
| | #3 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,714 ![]() | Hi Tim and welcome to the router forums.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please edit your profile with a name and location so we can better assist you and make for a friendlier forum. |
| | #4 |
| Senior Moderator Supreme Forum King | Tim, I am guessing you have heard of using a router to edge join boards and thought a router could replace your joiner. While it is possible to completely surface a board with a router it is a very long process. The joiner is the right tool for this job. Surfacing is quick and easy, you can easily cut accurate 90 degree edge angles and then use your saw or planer to squiare up the boards. Depending on the joiner you may also be able to make quick and easy rabbit cuts.
| | #5 |
| Registered User New Member | Thanks everone for your replies. You have helped me decide on keeping the jointer. I know its not the best you can buy but I think I can by with it. I only payed 160.00 can, reg 270.00,but it will due for now. Tim |
| | #6 |
| Retired Moderator Supreme Forum King | I have been considering this as well. I bought a craftsman jointer and found it to be junk.. the fence was aluminum and could not get it square to the talbe. Took it back and bought the 5 1/4 model or something like that.... same deal. Need good cast iron table and fence on a jointer. I got my money back on that one as well and have been jointer less for 15 plus years... I have a small shop and would like a small one that was worth something.. I just don't know if they exsist. Question to all of you, I have a bench dog router table that has a built in jointer feature where you put in these aluminum shims in the fence. (2 different sizes available) and supposedly you can joint a board on this. I bought some box stock on EBay and I am pretty sure I am going to need to joint these boards to get a square edge to rip on. Do you think it will work? I have a 1/4 spiral bit and a dozen or more 2 flute straights of different sizes? Thanks, Corey |
| | #7 |
| Forum Contributer Supreme Forum King | Just my 2 cents Yes it will work as long you stay under 1" to 1 1/2" thick stock. BUT It would better with Shear Angle Straight Bits http://www.mlcswoodworking.com/shops...r_angle_anchor http://www.mlcswoodworking.com/shops...r_angle_anchor Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-12-2007 at 11:22 PM. |
| | #8 |
| Retired Moderator Supreme Forum King | Thanks Bob, I will actually be using 3/8 and 1/2 inch stock, 20 inches long. I don't have the stock yet but will have to give this a shot. Corey |
| | #9 |
| Forum Contributer Supreme Forum King | You'er Welcome Corey You know me ,jigs and bits here's just one more way to put in a box joint in 3/8" or 1/2" in stock, this way will let you make all the parts in two passes on the router table,then use a 1/8" or 5/32" slot cutter to put in the bottom slot or the top slot. It's just a quick and easy way to make small boxes. ![]() Bj ![]() Just a great price for the bit /at about 32.oo bucks ▼ http://cgi.ebay.com/1-PC-1-2-SH-5-Sl...QQcmdZViewItem http://cgi.ebay.com/1PC-1-4-SH-Biscu...QQcmdZViewItem or this one ▼ you can see why I posted the 1st. one ![]() Box Joint Bit at 70.oo bucks http://www.mlcswoodworking.com/shops.../bt_windo.html
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-13-2007 at 12:21 PM. |
| | #10 |
| Registered User New Member | Challagan, I have the craftman 6" benchtop jointer. It has a cast iron bed and cast iron fence. It does great for me. It is a heavy little workhorse. I have never had a problem getting or keeping the fence square to the bed (table). |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 11:19 PM |
