How Deep Should The Mortise Be? - Router Forums
post #1 of 5 (permalink) Old 01-09-2013, 02:31 PM Thread Starter
First Name: Jerry
Over the past several weeks I have asked a lot of questions about mortises and tenons. However, in all of that time the issue of how deep a mortise should be has not come up. Right now the project that I going to be working on is, as I have said before, a small end table. The legs will be 2" x 2" and the workpieces that go between the legs will be of 3/4" x 3" material. I have been visualizing the mortiises being about 3/4" inch deep but am not sure that others with more experience would agree with this estimate and if not what would be more appropriate? Thanks
Jerry
Jerry Bowen is offline
post #2 of 5 (permalink) Old 01-09-2013, 02:47 PM
Jerry
I prefer to use the rule of thumb of 1/3 the thickness of the material you are going into for depth (mortise) and 2/3 the the thickness of the material you are going in with... (tenon) with all of the shouldering being the same...
Sizing can and will change depending on location, material limits and purpose...
post #3 of 5 (permalink) Old 01-09-2013, 04:31 PM
First Name: richard
I would make the mortise 13/16" and the tenon 3/4".
richtink is offline
post #4 of 5 (permalink) Old 01-09-2013, 05:38 PM
First Name: pat
2/3rds the width of the stick that receives the tenon is typical but often generous.
Can you tolerate any hardware?
Quillman is offline
post #5 of 5 (permalink) Old 01-09-2013, 09:17 PM
I always like to go as deep as is practical and since the mortices will butt into each other, that usually determines how deep they can be for me. Some like to 45 the ends so that each is maxed out.
Human Verification
Type Of Mortise Chisel To Square Slot Gaia Tools and Woodworking 50 08-29-2011 02:17 PM
Squaring Up Mortise And Glueing M & T Gaia Starting Off 4 08-03-2011 03:24 PM
Routing deep mortise Dalec Portable Routing 17 04-27-2011 03:50 PM
Deep Mortise Question mbg Tools and Woodworking 13 09-22-2009 02:12 PM
TS / Router / Mortise Combo PART1 kolias Jigs and Fixtures 1 05-04-2009 06:52 AM
