| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Dedicated Member | Curious if I could get some ideas about the pros and cons about the layout of different router table configurations. For example : Insert plate located in the center of the table vs the insert plate located off center closer to the table top edge. -and/or- Different sizes of table top recommended. Thanks, this is my first and have high expectations ![]() |
| | #2 |
| Registered User Forum Fanatic | I am starting one like Bob and Ricks. But I plan to make it a bit wider both front to back and left to right. No special reason other than i have room for it and i can cut it down if i don't like it. The extra length allows a longer jointer fence to be used. |
| | #3 |
| Registered User Sr. Member | Mine is rectangular and the insert is in the middle of the table and I like it like that. No particular reason why either!! My table size is 700mm wide by 500mm deep. Seems to be big enough to me. Hope this helps, Aaron
__________________ The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ... |
| | #4 | |
| Registered User Dedicated Member | Quote:
Solid suggestion, I forgot about the Jointer option in considering a more compact functional table. I have the jointer on a larger table - but, it takes up too much room. Thanks again | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| routers and router tables | bahnthin | Introductions | 2 | 10-14-2007 10:49 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
