Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 11-04-2004, 10:45 AM   #1
Dan Butler
Dan Butler is on a distinguished road
Cool Raised Panel Router Bits
I am going to purchase a panel raising and rail and stile router bits. I will be using them in a router table with a PC 7518 3.25 HP fixed base variable speed router.
The primary intended use is for making raised panel doors. Do you have any recommendations as to manufacturer, style, etc. Should I buy a matched set? Ones with back cutters, etc?
Dan Butler is offline   Top - Reply with Quote
Old 11-04-2004, 04:25 PM   #2
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
There are a great many raised panel door sets available Dan.
It always looks better if the rail and style bits are the same shape as the panel bit.
i.e. all ogee, bevel, radius, ovolo etc.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 11-04-2004, 05:41 PM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
The panel bits with the back cutter, allows you to raise the panel without it being proud of the stile and rail when the door is assembled. I use CMT, and Freud, I also
have a set from Oak Park, they all work just fine. A matched set is probably the way to go since you can often get a deal on them.
Hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 11-20-2004, 01:30 PM   #4
dtoney5817
New Member
dtoney5817 is on a distinguished road
Woodline Inc has a cabinet set that is very good with a back cutter.
See Woodline.com
dtoney5817 is offline   Top - Reply with Quote
Bits for the Oak Park raised panel system Mike Router Bits - Types and Usage 15 11-10-2008 10:35 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
raised panel router bits Dave2 Starting Off 7 03-30-2007 11:13 AM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
1/4" router and raised panel doors BrianS Table-mounted Routing 12 05-19-2006 11:06 AM
