Belt sander slipping - Router Forums
post #1 of 11 (permalink) Old 06-22-2013, 07:56 PM Thread Starter
First Name: Col
Default Belt sander slipping
I have a Makita 75mm belt sander.
The last lot of belts are all a fraction too big which means that they slip .
Has anyone on here tried to increase the diameter of the rollers to combat this ?
Any help appreciated
Col
BlackbuttWA is offline
post #2 of 11 (permalink) Old 06-22-2013, 08:09 PM
First Name: Duane
Col
Don't know about Aus. but here in the USA, I think it would be easier to just change belt suppliers!
Dmeadows is offline
post #3 of 11 (permalink) Old 06-22-2013, 09:10 PM
First Name: jack
you might try some belt dressing spray Inside the belt might work ..just a thought jack
jack3140 is offline
post #4 of 11 (permalink) Old 06-23-2013, 04:59 AM
Harrison67's Avatar
First Name: Harrison
I knew a guy who used tape to make the roller bigger.
Harrison
Harrison67 is offline
post #5 of 11 (permalink) Old 06-23-2013, 06:11 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Use silicon self fusing tape on 1 roller or as suggested change belt suppliers or get the schematic and see if the locking lever is not doing its job.
good luck - baker
rwbaker is offline
post #6 of 11 (permalink) Old 06-23-2013, 02:43 PM
First Name: Michael
I have fixed the same problem by using a few rounds of tape on the rollers to build them up, might want to check the adjuster slides to be sure that dust has not clogged them to the point the rollers are not sliding all the way out when you lock them into place.
IGOR_481 is offline
post #7 of 11 (permalink) Old 06-23-2013, 06:04 PM
As others have suggested, the suspicion falls on the tensioning/roller slide mechanism.
No way should any belt be that oversize that the tensioner can't take up the slack. If it is the belts that are way over size, please take 'em back. The manufacturer needs to know they've got a problem!! If you only bought 1/2 doz. can you imagine how many dozens (thousands?) are potentially out there?
In fact, cut to the chase; phone the Manufacturer and let them know about the issue. If they're reputable, they'll just send you new ones (maybe some freebies for your trouble)>
DaninVan is offline
post #8 of 11 (permalink) Old 06-23-2013, 06:11 PM
Col;
I agree with the other comments about the slide-tensioner. I'd be highly suspicious that the tensioner couldn't take up any possible slack.
If it is in fact the belts please call the manufacturer, or e-mail them. They need to know they have a problem if it is the belts. The problem of taking them back to the retail outlet is that in all probability they'll not bother notifying the manufacturer. There could be hundreds or even thousands of non standard belts that are floating around out there.
DaninVan is offline
post #9 of 11 (permalink) Old 06-23-2013, 06:42 PM
Hi Col.
If the new belts are the same size,brand as the previous belts, I would say the problem is with the tensioner. Check for dust clogging up the mechanism. I recently changed belts on my belt sander and was amazed how much dust was there.
Sydney, Australia
jw2170 is offline
post #10 of 11 (permalink) Old 06-23-2013, 07:15 PM Thread Starter
First Name: Col
Thanks very much for all the suggestions.
I tried one of the old belts & even though it is well worn it still grips ok.
This was a new supplier to me.
Another lesson learned
Col
Human Verification
Conveyer belt slipping on double drum sander Billy Boy Show N' Tell 1 04-06-2013 01:46 PM
Belt Sander switch jph66 Tools and Woodworking 13 07-30-2012 12:41 PM
Harbor Freight Belt Sander Kelly Rittgers Tools and Woodworking 5 01-24-2011 01:01 PM
Makita Belt Sander kolias Tools and Woodworking 4 04-03-2010 07:46 AM
Belt Sander --- hand held or benchtop? Drugstore Cowboy Tools and Woodworking 14 10-20-2007 01:41 PM
