| This is a discussion on Bosch 5412L or Hitachi C12RSH ? within the Tools and Woodworking forums, part of the General Woodworking category; Anyone here used any of these? I'm thinking Bosch .. Thanks... |
| | #1 (permalink) | ||
| Registered User ![]() |
__________________ router è ancora il mio nome | ||
| | #2 (permalink) | ||
router, i these are my only two choices i would go with the bosch.. the price point on the hitachi alone is enough to scare me off. for that kind of money it should do morre than just cut wood. its only saving grace is that it has a smaller "footprint". great if space is at a premium. i would like to enter a 3rd contender into the race . Makita LS1013L. My first major tool purchase was the Makita without the laser. i wouldnt trade it for the world. also at $499 it makes my wallet smile. It can be picked up at any HD
__________________ scott even a bad day of woodworking is still better than a good day at work... | ||
| | #3 (permalink) | ||
| Registered User ![]() Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 2,431 ![]() ![]() ![]() |
Router, I agree with Scott on the Makita LS1013. It was my first major purchase also and I found one at a pawn shop for $260 (like new) and it is a great tool.
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. | ||
| | #4 (permalink) | ||
Thank you both George, Scott. Well, I must say that I think it’s a madness for the prices these Sliding Compound Miter saws are going for. For another 100 or so, a person could have a good quality cast iron table saw. As far as Makita LS1013L , that’s was my third choice if I consider a 10”. I’ve seen that for around 370. If I wasn’t so afraid of using table saws, and too lazy to set it up properly, I think that would cover most operations and there would be no need for glide compound saw. My concern is that can a table saw (with me operating it shakily and not setup 100%) produce as accurate angle cuts as a miter saw. Maybe I should just get a nother router :-)
| | #5 (permalink) | ||
Router I agree with you 100% about being scared of a table saw but you can get hurt with any tool if not used properly and proper set-up is a must for any tool to be used safely, especially the table saw. You can get acceptable miter cuts with a good, properly set-up, table saw but, as the name implies, you will get more accurate miter cuts with a miter saw (again, properly set-up). With my 10" Makita I can get up to a 16" wide cut by cutting half the board, flipping it over and cutting the other half. The only problem is you can't do rip cuts with the miter. For that you need a table saw or circular saw with a guide. Why not just get another router and a slide compound? You can't have too many tools. ![]()
| | #6 (permalink) | ||
| Retired Moderator ![]() |
There is no special trick to setting up a table saw. You open the manual and follow the steps listed. For those unfamiliar with this concept companies that build machinery of any type provide detailed instructions on proper set up that are easy to follow. This holds true for everything from toasters to Cincinnatti press brakes with 6 axis back gauges. If you are unable or unwilling to do this find somebody who will and pay them to do the set up while you watch. Ask questions, take notes so you can check to be sure everything stays in proper adjustment. Again, if you can't do this then pay somebody to come in and do it for you. A properly set up machine wont burn the toast or remove your fingers.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #7 (permalink) | |||
Mike, the key word for me was lazzzzzy when it comes to set up. I'm sure if I get one, I will not use it unless i take the time to do it right even if it takes a month or two Quote:
flipp/rip 28-30 inches?
__________________ router è ancora il mio nome | |||
| | #8 (permalink) | ||
| Marine Engineer ![]() |
From a quality standpoint, all I can say is I have a 10 inch hitachi slider, and it's an awesome tool. http://cgi.ebay.com/Hitachi-C12LSH-1...QQcmdZViewItem Check the reconditioned ones at ebay, other online sellers. | ||
| | #9 (permalink) | ||
[quote=So george, If you have a 15" miter glide saw would you say it's possible to flipp/rip 28-30 inches?[/QUOTE] Excuse me Router but I made a mistake on my previous post. I can actually get more like a 22-24" cut with my 10" Makita, although I have never had occasion to do so. The width of rip would depend on the travel of the slide on your saw. Not knowing the travel on a 15" saw, I couldn't say, but that may well be.
| | #10 (permalink) | ||
If you intend on doing any type of "ripping" is should be done on the TS with a good rip blade. Miter saws are for cross cutting not ripping. Please read any all manuals with your tools, don't use them for something that they aren't intended for. If you want to go a cheaper route.... use a circular saw and a fence/straight edge, this is an easier setup than you may think. If you are intent on getting a miter saw, check amazon, they have used and new, prices probably equal that of ebay but, you never know til ya check it out.
__________________ Ken ***Please fill in your profile, at least your location. As this will help us help you better.*** "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown Woodworking Router FAQ's http://www.routerforums.com/routerfo...ssistance.html | ||
| Bosch 1617EVSPK or Bosch 1619EVS | LBrandt | Table-mounted Routing | 24 | 01-25-2010 04:28 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 10 | 10-24-2009 06:34 PM |
| Hitachi M12V and Bosch 1619EVS routers | LBrandt | Table-mounted Routing | 3 | 06-03-2006 11:42 AM |
