Using Biscuits With Mitered Corners - Router Forums
post #1 of 19 (permalink) Old 09-11-2013, 05:33 AM Thread Starter
First Name: Jerry
Default Using Biscuits With Mitered Corners
Several days ago I asked about and/or talked about my interest in learning about using dowels, One of the places that I am thinking of using them is for jointing mitered joints such as in a shadow box project. In other words the miter corners are such as you might use in the construction of the corner of a box and not in the application of a frame where the workpieces lay flat as in a picture frame for example.
Anyway, Harry posted to my thread said that he liked to use biscuits and I responded that I have used biscuits in that type of joint. With all of that said, my question to Harry and others that use biscuits for this type of joint is this. My biscuit cutter works best when cutting the slots in the workpieces with cutter setting on a 90 degree edge and not so well on 45's. the only way that I have been able to cut the slots for the biscuits is to put two workpieces back to back so the the ends of the workpieces
form a 90 degree shape and this allows the cutter to have the 90 degree profile that is required to make the cuts. Hope you follow what I'm attempting to describe.
My question is that I'm wondering if there is another and/or a better way to cut the slots for the biscuits in such a joint? Because this approach is a little cumbersome has caused me to think about the possibility of using dowels instead of biscuits but don't kow if there is a doweling jig that could be used or not, seems like I saw a demo of a jig for this application, but can't seem to find it again. Sooo, if anybody has any ideas and/or thoughts along this line of thinking, I'd like to hear from you. Thanks,
Jerry
Jerry Bowen is offline
post #2 of 19 (permalink) Old 09-11-2013, 06:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
Jerry
Jerry, if this very old el-cheapo GMC jointer is capable of perfect 45 slots I can't imagine any machine that isn't. Perhaps these shots will be of some assistance.
Harry
harrysin is offline
post #3 of 19 (permalink) Old 09-11-2013, 10:19 AM Thread Starter
First Name: Jerry
After some back and forth via e-mail with Harry who assured me that there was a way to make cuts in question with my biscuit cutter, I found that the cutter can indeed be set up to make the cuts. I am so thankful for help from members on this forum, in this case, one of our dear friend from "Down Under". Thanks Harry.
Jerry
post #4 of 19 (permalink) Old 09-15-2013, 02:08 PM
First Name: MIKE
Is tis method usable for compound miters in 11/16 stock?
mikelley is offline
post #5 of 19 (permalink) Old 09-15-2013, 05:08 PM Thread Starter
First Name: Jerry
Default I'll Have To Think On It Mike
Mike,
I've have not learning to cut compound miters in any easy way yet, so I'll have give your question some thought. Sounds like an interesting challenge, I'll get back to you on eit.
Jerry
post #6 of 19 (permalink) Old 09-15-2013, 09:59 PM
Honored Member
harrysin's Avatar
First Name: Harry
I see no reason why not.
Harry
harrysin is offline
post #7 of 19 (permalink) Old 09-16-2013, 06:27 AM Thread Starter
First Name: Jerry
I'm still thinking about the compound miter issue. Right now I invision the normal 45 degree cut which is one of the cuts on the compound miter cut, but the other angle might only be 15 to 20 degrees which might require a similar jig but made at the lesser angle so that the lesser angle allows the edge of that cut to lay at 90 degrees to the slot cutter in order for the slot to be square to the face of that lesser angle, then all should work. Just seeing this in my haed as how to do it, am I missing anything, other than how to make the second jig that is used for the second or lesser angle, gotta work on that yet.
Jerry
post #8 of 19 (permalink) Old 09-16-2013, 07:23 AM
I believe, Jerry, a compound mitre is not the same as a simple angle (not 45).
A compound mitre has the face at an angle to the table .
Sydney, Australia
jw2170 is offline
post #9 of 19 (permalink) Old 09-16-2013, 07:58 AM
Honored Member
harrysin's Avatar
First Name: Harry
Jerry
How about a translation in plain English Jerry!
Harry
harrysin is offline
post #10 of 19 (permalink) Old 09-16-2013, 10:21 AM Thread Starter
First Name: Jerry
Harry,
Let me see if I can do what you ask. I will start by just assuming that anybody that cares about what I'm talking about already knows what a compound miter cut is and so I do not then have to explain how to make one or what it is.
In my first attempt to explain what I am talking about I used a term "lesser angle". What I meant by that term refers to the area at the ends of the four workpieces where the slots for the biscuits are to be cut are not square with the faces of the workpieces, they are at a slight angle slightly less than 45 degree, thus less than 45 degree and why I called the angle a lesser angle. Consequently a jig for cutting slots into an edge that is 45 degrees to the face of the workpiece will not work when cutting slots into a "lesser angle" and a second jig needs to be constructed if you want the slots for biscuits to be cut at the proper angle. Of course, since the slots cut for biscuits are such that the bisucits fit tight in them, there is probably enough wiggle room to pretty much just off set the piece a little by hand so that the joint still works out. Sure turned into a lot of back and forth about may be a moot point and I should not have even gotten myself into the situation.
Is that a better explanation Harry? Hope so, and maybe I have mopped up the spilled milk so to speak.
Jerry
Human Verification
Looking For A Doweling Jig For Mitered Corners Jerry Bowen Tools and Woodworking 9 08-26-2013 06:18 PM
Mitered corners Mike The Voting Booth 27 10-11-2012 08:16 AM
Rounding a mitered corner? nannienine General Routing 7 04-11-2012 03:21 PM
Mitered raised panel doors bobj3 Table-mounted Routing 13 09-03-2010 12:37 PM
Trimming mitered hardwood edging Drew Eckhardt General Routing 5 10-11-2008 07:59 PM
