| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Dedicated Member | Does anyone use a cabinet scraper and how the heck do you sharpen one? I need an easy short way to do this on a rectangular scraper. g-man |
| | #2 |
| Registered User Supreme Forum King | Look at: www.leevalley.com or catalog page 38 (2004/2005) They have a Veritas jointer/edger and various burnisher tools. Ed |
| | #3 |
| Router King Supreme Forum King | You sharpen a scraper as you do a chisel, pay attention to the angle (bevel). Do not remove the burr as this is what does the cutting.
__________________ |
| | #4 |
| Registered User Forum Fanatic | You hold the scraper flat on your work bench with you left hand (if your right handed) sharpen the edge with the burnishing tool, flip it over do the same thing to the other side.You realy have to wip the heck out of it .. then stand it up in a vice and run your burnishing tool flat across the edge til you can fell the berr with you finger nails when running them up the side. when you fell this your done ..good luck. It is realy easy Learning Herb
__________________ I try to learn some thing new each and every day ,Learning Herb
| | #5 |
| Registered User Supreme Forum King | Just a couple of things to add. One if the edge is chipped or no longer flat you will have to sharpen it. To do that you need to go with the length of the scraper, on either a stone or a file (I like to use the file). This will remove the wire edge. To put the edge back on you need to burnish...... The problem is you want a slight angle to it. The angle is a matter of personal preference. This is why some people spend the money on the tools to get it the way they want..... When they are right they work great until your hands get like mine and it hurts to use them for very long. Now I save it for special projects. I have seen a "plane" scraper but I haven't tried that. Anyone have one and want to comment? Ed |
| | #6 |
| Router King Supreme Forum King | I'd like to add to Ed's post. The proper name for the wire edge is "hook". Found that out yesterday.
| | #7 |
| Registered User Dedicated Member | Okay I did it but, one instruction sheet I found on the net said to put a 45 degree angle on it. So I did this on a wet wheel and it got razor sharp and I found out that a 45 degree angle would only be on one side. Well it was too late to do it over so I flipped it over and cut another 45 on the other side. I put it in a vise a drew a burr with the flat part of a chisel. I did this a few more times on both edges and got a good hook. It works good. Maybe I'll be daring later and grind the edges flat and start a 15 degree grind so I can draw a burr on all four edges. LIVE AND LEARN! g-man |
| Spice Cabinet | Lee Brubaker | Show N' Tell | 10 | 03-21-2008 01:47 PM |
| CMT Industrio Router Table System (orange cabinet) | Ladd | Table-mounted Routing | 50 | 02-06-2008 12:34 PM |
| Trying to replicate cabinet door, looking for help | AKF | Tools and Woodworking | 7 | 12-28-2007 09:44 AM |
| China Cabinet | lrr | Show N' Tell | 27 | 03-01-2007 11:16 PM |
| Fastening Router Table To Cabinet | DONALD | Table-mounted Routing | 7 | 04-03-2005 12:04 PM |
