| This is a discussion on I need help! Dewalt Planer Question within the Tools and Woodworking forums, part of the General Woodworking category; I have a Dewalt 2-blade planer and until yesterday I had no complaints with it. ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have a Dewalt 2-blade planer and until yesterday I had no complaints with it. Except, the occasional wish that it was an inch wider ![]() Yesterday I had to change the blades due to two nicks that were causing me no end of grief (the culprit offered to pay for the sharpening so all is good there). Prior to changing the blades the planer never sniped, at all; after I changed the blades I used it successfully to plane some cherry legs for a stool I am making, but when I used it to plane a piece of maple it started sniping rather severely. I thought I used the depth gauges properly, but obviously I didn't do something right. Does anyone have any tips as to how to fix this? | ||
| | #2 (permalink) | ||
try posting this queston om www.forums.woodnet.net. You might run into some one over there how will know about that, Learning Herb
__________________ I try to learn some thing new each and every day ,Learning Herb | ||
| | #3 (permalink) | ||
In case anyone else has the same problem with their DeWalt planer (DW733)... It turns out that if I had put the blades in using what is called, "The Right Way" I would have had no issues ![]() I aligned the blades last night and realized that I had not pushed one of them back far enough and it was sticking out about 1/16 inch more than it should be. No wonder I had so much snipe. | ||
| | #4 (permalink) | ||
| Retired Moderator ![]() Join Date: Sep 2004 Location: Mountain Top Pennsylvania First Name: Glenmore Posts: 2,011 ![]() |
Thanks for the warning on this I have a DW733 in which I have to change the blades real soon myself. | ||
| | #5 (permalink) | ||
The reason I didn't set the blades correctly the first time was that I couldn't figure out how to use the blade depth gauges and the socket wrench at the same time. When I was trying to fix my mistake, I noticed a little wrench attached to the guard that was able to fit in behind and tighten the two end bolts. My forehead was a little sore after that ![]() | ||
| dw735: get the dewalt folding tables or build my own? | kleptic | Tools and Woodworking | 19 | 06-27-2008 02:52 PM |
| DC Question | angus | Lobby | 3 | 03-31-2008 07:29 PM |
| Question about DeWalt DW618PK | texan123 | General Routing | 6 | 12-13-2007 09:01 AM |
| planer decision... | reikimaster | Tools and Woodworking | 9 | 10-08-2007 11:27 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 06:42 PM |
