Rate This Thread - Drum sander help please?.
Thread Tools Display Modes
Old 04-18-2007, 07:15 PM   #1
Birch
Sr. Member
Birch is on a distinguished road
Default Drum sander help please?
Purchased a set od drum sanders. Slid one of the two inch "belts" around the drum, chuck'd er up and hit the switch. Appears to me a body would be well advised to run those things at slower speeds. What say the Wise Wood Men...slower speeds for drum sanders?
Incidentally, the little set I bought has five or six drums, clear down to a 3/4" with "belts" or "sleeves" to fit. What would a guy use that small a sanding drum for?
Thanks.
Birch is offline   Top - Reply with Quote
Old 04-18-2007, 09:35 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Ok, you chucked the sanding drum up in your drill press and set it to the lowest speed? This is the way to use the drums. The reason for the different size profiles is to allow you to get into tight curves with the smallest, the largest is best used for fairly straight edge work.
Old 04-18-2007, 10:02 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
Are you talking about this type of drums ?
http://www.grizzly.com/products/h2271
to fit on a Spindle Sander
http://www.grizzly.com/products/g0538
Can you post a sanpshot of it sure would like to see it.
Bj
By the way slow speeds are best, that's to not to low and not to high , it will burn the stock at high speed , the small drums will come handy in the tight circles..
Thanks.
bobj3 is online now   Top - Reply with Quote
Old 04-19-2007, 05:20 AM   #4
Birch
Sr. Member
Bob3: The drums I bought are only 2" or so long, by various diameters. Got a set of them from Rockler, just down the road from me. I use them on a BIG 5-Speed Chicago drill press I bought at a farm sale for $50!!! Way more than I need but Jeeze...who could pass it up!!
My instincts were right.....slower speeds.
Old 04-19-2007, 02:00 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
Is it the one below, if so I have this set also, it's a great tool to have in the shop
and will come it handy for may jobs
http://www.rockler.com/product.cfm?p...anding%20drums
Or this one
Bj
Old 04-19-2007, 03:28 PM   #6
Birch
Sr. Member
It was the first set Bob. I have thought about the fancier one for later maybe. But when I slowed by drill press down to 750RPM it made a BIG difference. Oh...any trick to getting the sleeves to stay on? They sorta adhere on their own in a way don't thry.
Old 04-19-2007, 03:57 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
Just the little nut,should hold them in place, it should make the drum bigger when you turn is backwards , left hand thread
You can'd glue them in place because they must come once they wear out.
By the way one of the rubber stick will made the drum disk last longer.
rubber eraser stick=1 1/2" x 1 1/2" x 8' long the norm.
http://www.grizzly.com/products/g1511
Bj
My big mistake- v- drum sander trap Tools and Woodworking 2 05-06-2008 04:27 PM
V Drum Sander trap Tools and Woodworking 4 05-03-2008 11:40 PM
Drum Sander trap Tools and Woodworking 10 04-03-2008 09:39 AM
Delta 18-36 Drum Sander dustmaster Tools and Woodworking 1 08-02-2005 10:31 AM
Performax 10-20 plus drum sander reible Tools and Woodworking 2 01-02-2005 06:55 PM
