| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Forum Geek | About 6 months ago I got a Delta contractor saw. It worked great and have had no problems with it. Until now. I was kind enough to let a very good friend use it. Most of my friends know well enough that most of my hand tools and smaller equipment can be borrowed until I have to go get it myself or it is returned in not so good condition. Then that is it. One strike and your out (I know it's a little harsh, but got severly burned in the past). I let my buddy use it in my garage this past weekend while I was away. He is a good enough friend to have a key to the garage and is more than trustworthy and has never let me down before. I went out to make some dust tonight for a small box for the lady. It appeared to me that my cuts were just a little off compared to normal. After checking every angle with the prehistoric angle, etc that I have, I have come to the conclusion that my glasses were on straight and that the saw is cutting off kilter. I changed the blade and still there. What suggestions, tools, help can you members of the forum offer me?
__________________ It's all good till it's no good anymore. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi rh111 Some of the table saws have 2 screws under the top that will set the blade, he may have jam a board and it took it out of wack. ![]() 1st unplug the saw, then turn it on it's side and then with a light check out the bottom side of the saw, if you have the user manual it will show the spot for the adjustment screws. Once you find them turn the saw back on it's legs and remove the saw blade ( I use a metal chop saw blade to set them up,because they are flat) ) and get a sq. and use the opening in the table to set the blade back to sq./true once you have it set move the fence in to the sq. ( the long blade on the sq.) turn the blade by hand and check it, then check it one more time then check it one more time, once your sure it's right move the fence back and put the blade plate back in place and try a test cut. Good LUck Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-26-2007 at 12:01 AM. |
| | #3 |
| Forum Moderator Supreme Forum King | rh, Is your square exactly square? Just something you may want to check also.
__________________ Cheers, Bob |
| Alignment jig | Router is still my name | Tools and Woodworking | 4 | 12-08-2007 03:30 PM |
| "Lo-tech" table saw blade alignment | simplenik | Tools and Woodworking | 1 | 07-08-2007 06:06 PM |
| Rail and Stile alignment....HELP | arkwood | Router Bits - Types and Usage | 8 | 01-10-2007 12:07 PM |
| Fence Alignment | Smoothcut | Introductions | 3 | 05-12-2006 09:04 PM |
