Rate This Thread - Adhesive.
Thread Tools Display Modes
Old 05-01-2007, 11:35 AM   #1
mickiedoo
New Member
mickiedoo is on a distinguished road
Smile Adhesive
I am attaching a 1/4" veneered plywood to a cabinet I am refacing. What type of adhesive would work best? I was thinking contact cement but I'm open to suggestion.
mickiedoo is offline   Top - Reply with Quote
Old 05-01-2007, 01:01 PM   #2
cabinetman
Forum Fanatic
cabinetman's Avatar
cabinetman is on a distinguished road
Without knowing what's on the surface of the existing cabinet, my first preference would be to scuff sand to where you have some porosity, and use Titebond II with cauls or clamp so that you get even area pressure across the surface. If that isn't possible, and in many situations it isn't, use a solvent base contact cement, and follow instructions. Cut your piece slightly oversized and trim off after laminating. Use a slip sheet of formica or thin plywood, or even a series of dowels to keep the two parts from touching while you line them up. Allow for good ventilation, and after laminating, press down with the edge of a block of wood or tap with block of wood and hammer to get good contact.
cabinetman is offline   Top - Reply with Quote
Old 05-01-2007, 01:08 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
And if you need a bit more working time you can use Titebond III.
Old 05-01-2007, 01:29 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi mickiedoo
You may want to check out the new glue from Loctite it's great stuff and you can clean up with water
I tried a tube last week and it worked out great on 1/4" plywood, it's not cheap but it works and it's fast.
I got the tube from Home Depot
http://www.loctiteproducts.com/glue.asp?PLID=482
http://www.loctiteproducts.com/glue.asp?PLID=662
Bj
Old 05-01-2007, 01:54 PM   #5
mickiedoo
New Member
Hey, thanks for the info guys.
Old 05-01-2007, 08:30 PM   #6
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
http://www.newwoodworker.com/reviews/titebond.html
and my personal all time favorite mess
http://www.newwoodworker.com/reviews/gorilaglurevu.html
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Plastic laminate S Bolton Table-mounted Routing 12 03-16-2008 06:40 PM
