Rate This Thread - Couple gadget ideas..
Thread Tools Display Modes
Old 05-07-2007, 06:40 AM   #1
Birch
Sr. Member
Birch is on a distinguished road
Default Couple gadget ideas.
Two things, but you old time guys may know all about them. First, I found a "sanding block" at Walmart the other day, about 4X6" that has a heavily ribbed rubber bottom. I'm sure it works as a sanding block, but it REALLY works as a nice push block. And costs less than $5. And I guess you COULD use it for sanding too.
Second, I bought and installed an MJ Splitter on my T-saw. Yes, I know you can fabricate something similar, but this little dandy is for us new guys. I wish the instructions were a little more clear. Go to the MicroJig site (same people who make the Grrrriipper) and check it out. I LIKE it.
I am now working on a blade guard design. I can't help it.....running that saw without something over the blade just makes me nervous!
Okay. Thats all. You guys are probably way ahead of me.
Birch is offline   Top - Reply with Quote
Old 05-07-2007, 08:04 AM   #2
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Hey Birch..... Great idea on the sanding block using it as a push block. Never thought about that one.
I have the micro jig splitter and the Grr-Ripper as well..... would not be without them. Corey sold me on the idea and I thank him every time I use the TS.
Cheers,
Bob
Pictures from the shop
http://s107.photobucket.com/albums/m292/bnoles616/
Bob is offline   Top - Reply with Quote
Old 05-07-2007, 09:28 AM   #3
cabinetman
Forum Fanatic
cabinetman's Avatar
cabinetman is on a distinguished road
Here's an old guy idea. Going back to the sanding block, I make mine using a 3"x18" or 3"x21" sanding belt in grits from 50x on up. I take a 3" piece of 5/8" or 3/4" plywood and cut it 3"wide and cut it to length to push tightly into the sanding belt. The end edges should be eased a bit to keep from tearing the belt when inserting. Also make a slight bevel on the corner that gets fed into the belt to help guide it. This "block" sander gives a wide area and is very easy to use and it's inexpensive.
cabinetman is offline   Top - Reply with Quote
Old 05-07-2007, 05:55 PM   #4
rmaxa
Forum King
rmaxa's Avatar
rmaxa is on a distinguished road
Cabinetman, I'm not able to see your pics
Rolf
Rolf
"I love it when a plan comes together"
Hannibal Smith
rmaxa is offline   Top - Reply with Quote
Old 05-07-2007, 06:43 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rolf
No pictures ,just his signature jpg, Mark had to disable the jpg for a bit to fix the error on the forum, with jpg in the signatures .
Bj
Rolf
bobj3 is online now   Top - Reply with Quote
Old 05-07-2007, 07:13 PM   #6
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Excellent idea Birch. I think I have one of them old boys in a box some where!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 05-07-2007, 07:26 PM   #7
cabinetman
Forum Fanatic
cabinetman's Avatar
Rolf
I didn't post any. The URL is for my signature that is not opening up. Mods are trying to fix the problem. But, thanks for reading the post.
Old 05-08-2007, 06:09 AM   #8
Birch
Sr. Member
Just a quick followup: the sanding block from Walmart is solid rubber or plastic, has the wire clips front and rear to hold sandpaper, BUT it is the bottom I like-very closely spaced ribs and entire bottom rubber, soft, like an eraser. Put it down on a piece of plywood and it sticks like glue!! So cheap you almost can't afford to waste time making one!
And CHEAP is my middle name. Actually, "chips" is my middle name. HA!
Jersey Frame Ideas longashes Table-mounted Routing 1 04-27-2008 07:10 PM
Need A Few Idea's...... challagan Tools and Woodworking 3 01-11-2007 08:47 PM
New Contest Ideas Mark RouterForums.com News & Feedback 22 11-23-2006 05:37 PM
[8/28/06] New Forum Ideas Mark RouterForums.com News & Feedback 4 09-04-2006 03:21 PM
Ideas, Ideas people?!?!?!?!?!? Kevin Lobby 3 11-03-2004 09:34 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
