Rate This Thread - How can I hang this on the wall?.
Thread Tools Display Modes
Old 05-09-2007, 10:32 AM   #1
bmkiss67
New Member
bmkiss67 is on a distinguished road
Question How can I hang this on the wall?
Ok, so I'm new to woodworking and I know that there are millions of beginner type projects out there, but I decided to go with something I could use now. I live in a townhouse with little space and I have 2 road bikes. My problem is I need to find a place to put my bikes so my solution is to make a set of hangers for them. So I decided to make them out of wood. Here is a pic of it, the little blue area represents the wall.
Those grey things are my plan. I figure I would take 2 18"x2"x12" boards, cut them on an angle, and route out the curve that you see in the top corner. I figure two of these about 18" apart would hold a bike nicely. Here is where my problem is, how do I attach those hangers to the wall, interior drywall, securely enough to hold a bike up? Any suggestions would be greatly appreciated.
Thanks a lot for listen.
bmkiss67 is offline   Top - Reply with Quote
Old 05-09-2007, 12:56 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi bmkiss67
I would use the key hole way ,, you can't see and fastners and if you put the screw into the 2 x 4 in wall it will hold it.
Drop on and hang thing
Small note**** if you don't have a keyhole bit and Dovertail bit will work also...just drop it in the stock then move it down the stock about 1 1/2" long then just pull it back up,, don't try and back it up in the slot...
One hole in each should do the trick,but you can put two holes in each for a failsafe..
Key Hole bit below.
http://www.mlcswoodworking.com/shops.../bt_keyhl.html
http://www11.brinkster.com/bmkiss67/bikehanger.jpg
Bj
Old 05-09-2007, 02:50 PM   #3
bmkiss67
New Member
Hi Bobj3,
Thanks for the info/advice. I do have a question about your drawing. The 3/8 O.D. is telling me that to get a bit with a large dia of 3/8". The part I don't know what to do with is the 1/2" deep part of the pic. Could you explain that if you don't mind.
P.S. I did mention that I was new to woodworking.
Old 05-09-2007, 03:05 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi
Use the #5438 this hole is just the right size for a dry wall screw (8 x 2 1/2") to drop in and lock. (most drywall walls are 3/4" thick in the garage)"firewalls"
When you drop the bit in the wood set it for 1/2" deep, you can do this with your plunge router with the edge guide or on the router table, (router table is best ,it will help you keep it true to the side of the stock.
Just a NOTE**** once you make the slot, power down the router and move it back to the start point, then remove the router or stock,then do it one more time, masking tape on the router table fence works best to give you a start point and a stop point.
"P.S. I did mention that I was new to woodworking." we all are
Use some scrap stock for your test slot...
Bj
Old 05-09-2007, 03:40 PM   #5
bmkiss67
New Member
Hi,
Thanks for the help. Just one more question. This is actually going in my basement, I don't have a garage, I wish I did, but I don't. Does that make a difference?
Old 05-09-2007, 04:07 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi
You'er Welcome
No, you may not need a 2 1/2" long screw a 1 1/2" to 2" will work fine.
Bj
Originally Posted by bmkiss67
Hi,
MDF Kitchen wall clock bobj3 Show N' Tell 40 05-18-2008 02:46 AM
thin wall pvc pipe problem timothy Introductions 6 04-22-2008 11:02 PM
Best Router for Cutting Slots - Slat Wall RAKESS Table-mounted Routing 0 01-27-2008 03:36 PM
Multi Profile Bit - Wall Chart ??? garycurtis Router Bits - Types and Usage 10 10-02-2007 05:07 PM
Wall Shelf w/ Sliding Dovetails Joe Lyddon Show N' Tell 45 08-15-2007 08:25 PM
