| | #1 |
| Registered User Supreme Forum King | I have strips of laminated wood cut-offs. Can anyone tell me how to make my own dowels from these? |
| | #2 |
| Registered User Dedicated Member | |
| | #3 |
| Router King Supreme Forum King | Check out this like, Bob and Rick already have an article. http://www.routerforums.com/showthread.php?t=304
__________________ |
| | #4 |
| Registered User Supreme Forum King | I apologize. I was way too vague with my question. These cut offs are only 1/2"-3/4" square, and 3"-5" long. I really was looking for a quick way to round these off, other than sanding. The bullnose method just seemed a little dangerous to me. I read once that someone put wood in their 1/2" drill and held it to a stationary belt sander. Maybe I'll try that. Thanks for the responses. Kevin |
| | #5 |
| Registered User Supreme Forum King | Do you have a spoke shave? That can get you almost round then the drill and sanding could finish them up. Ed |
| | #6 |
| | #7 |
| Registered User Forum Fanatic | That Lie Neilson plate is a multi size dowel die whereas you can make your own very easily like carpenters have done for centuries. Drill a hole in a steel bar approx 1/4" thick to the required dowel diameter then turn this die over so the burr is pointing up to cut the wood. Put a chamfer on each piece of wood so it can start in the hole then with the die well supported hammer the wood through the hole. You now have a dowel of the required size. Because the wood is being compressed slightly when passing through the die the hole is often drilled slightly smaller. i.e. 31/64" for a 1/2" dowel.
__________________ Dewy support team at Paltalk voice chat program |
| | #8 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #9 |
| Registered User Supreme Forum King | Thanks for all the responses. I really appreciate the good advice. Kevin |
| | #10 |
| Senior Moderator Supreme Forum King | Boxer, have you thought about glueing your pieces together into a useable size? Some very cool results come from laminating different woods together. Just a thought. Happy woodworking! |
| Tenon sizes | ACV | Table-mounted Routing | 11 | 03-20-2008 02:46 PM |
| wooden sign suggestion | sawdustlisa | Introductions | 56 | 09-14-2007 07:23 PM |
| Room divider finished | jigger | Jiggers Gallery | 9 | 07-25-2007 01:29 AM |
| lettering nightmare | Birchwood | General Routing | 19 | 10-18-2006 08:52 AM |
